Join the Community today
Username Post: PERMANENT: Canadian Chevrolet information 1929-42        (Topic#96359)
Anonymous
04-03-05 11:39 PM - Post#664209
Vintage Historical Services at GM of Canada in Oshawa have sent out to owners of Canadian Chevrolets in the past details of serial and engine number runs for cars, light delivery and trucks. This information is reputedly now no longer available and over the years I have been collecting copies of the original data sheets from owners who were sent them years ago.
If anyone has any of these sheets please let me know! I am building a definitive database of Canadian Chevrolets and Pontiac, Maple Leaf and GMC chassis that used Chevrolet engines and these data sheets will assist me complete it. Luckily for passenger cars we know except for perhaps one year, serial number runs and also engine numbers because the same series applied to cars, l.d. and trucks.
Fernandoraviol
Reg: 06-19-05
Re: 1929-40 Canadian Chevrolet information?
06-19-05 05:45 AM - Post#664210
    In response to
Hi: Where can I find informations sucha as model code ,etc for my Chevrolet 1929or 30 sedan 4 doors motor 835501 serial No101871 right hand drive??? thanks
Anonymous
09-17-05 05:03 AM - Post#664211
    In response to Fernandoraviol
I am sorry but I had not picked up the query! The # 835501 and # 835503 are the 1929 casting numbers for the cylinder block and head, whereas 1930 was 835501 and 836723. The serial number proves it is not Canadian. The car was probably assembled by General Motors de Argentina, Buenos Aires..look for a 'XC' code on the build plate. The engine number will have a 'R' in front and is stamped on a pad on the block. I think that the carw as sent out as a kit of parts from Bloomfield, New Jersey Chevrolet Boxing Plant.
greyoneca
Loc: Ontario, Canada
Reg: 11-03-05
11-03-05 05:03 AM - Post#664212
Good morning, not sure if you could help me?
I have a 1939 Canadian built Pontiac Arrow model sedan with a six cyclinder motor. My problem is do think the motor is the one that came with the car when it was new. Few people have told me that in 1939 GM Oshawa was gearing up for the war so "strange" things may have happen.
The VIN plate on the car is as follows:
Model - 22 - 19
Serial; 9221900974
Engine; 1298992
Body Serial; 237
Trim; 265
Paint; 900
When I looked at the engine number on a small machine block on the right (passenger) side of the engine at the front I read; 96381 (reading left to right). This number is stamped on.
The casting number, again on the right side of the engine towards the back is GM and under that G57, reading left to right. These letters and number are raised.
Any help/information/pictures you could provide that would assit me in identifying this engine is greatly appreciated.
Thank you
Bob Lalonde
greyoneca@yahoo.com
Royer
Needs to Get Out More Member
Royer
Loc: Bloomfield Hills, Michiga...
Reg: 09-25-01
11-03-05 05:13 AM - Post#664213
    In response to greyoneca
Being from North of the border (US that is - check out a map of the Detroit/Windsor area if you doubt it), I'm not familiar with a Pontiac "Arrow" model, though I do know that the lowest US Pontiac series did use the same "A" series body as did Chevrolet in '39. The question I'd have (that I didn't see mentioned in your post): is your car powered by what appears to be a Chevy 216 cubic-inch OHV engine, or does it use a Pontiac flathead six?
Royer
greyoneca
Reg: 11-03-05
11-03-05 05:23 AM - Post#664214
    In response to Royer
Thanks for your response. Two appraisals list the engine as original one states "Orig. 224 C.I.". There in lies my problem, not sure what the engine is do know it is not a flat head. Think the Arrow model was a Canadian thing. At a show in Potiac MI someone said the car was a Chev. from the front window back.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
11-03-05 08:47 AM - Post#664215
The engine is an overhead valve 1939 Chevrolet 216 with a larger bore and aluminum pistons.If I remember correctly the bore is 3 9/16" VS the 3 1/2" 216 bore.The Chevrolet had an enclosed drive shaft and did not have an X type frame where as the Pontiac had an open drive shaft and an X in the center of the frame.I would suspect that the frame,running gear and suspension are all Chevrolet.
greyoneca
Reg: 11-03-05
11-03-05 08:59 AM - Post#664216
    In response to Gene_Schneider
Hi, think the information coming is just great. I do have a picture of the engine and car and if someone would tell me how to post I would do so and maybe my mystery would be solved.
Thanks again
Greyoneca
Anonymous
11-03-05 11:39 AM - Post#664217
Hi again Mike! The Pontiac Arrow Six was basically a Canadian Chevrolet in Pontiac clothes whereas the Chietain Six wjich also used the Chevrolet shell and running gear with Pontiac styling had the Chevrolet 216-based 224 cu in engine...'Cheviacs' as someone once said. By 1942 the 'Cheviac' idea had been dropped and Oshawa reverted to clones of the US Pontiacs, but then revived the idea in 1955 and then continued for many years. In 1955 they offered the essential six option, the 235 Chevy-based 261 'Astro-Six' when US Pontiacs had gone all-V8 in addition to the range of Chevy V8s.
1939 Walkerville Plant Chevy/Pontiac Arrow Six/GMC engine numbers:
# 1288953 - # 1305600
# 1972801 - # 1997876
with 'C' for light truck, 'T' for 'Truck' and 'R' for Right hand drive' by itself or in front of 'C' or 'T' as appropriate.
1939 Canadian Pontiac numbers:
ARROW SIX
922XXetc OSHAWA...# 00001 TO 04313
922XXetc REGINA ...# 80001 TO 80972!
CHIEFTAIN SIX:
925XX SAME sequence BUT MOTORS # W-27060 TO 29439 [224 CU IN] so you can deduce how many of the total of 4,966 Pontiacs built in 1939 were 22XX by deducting the number of W-prefixed motors. 'K' was used instead of 'W' for GMC 224 engines.
However the engine that you have appears to have a casting date code of G-5-7, which suggests July 5th 1937 and therefore a 1937 unit. Candian 1937 Chevrolet engines ran:
R, C, CR, T or TR as the case may be:
# 64,201
39Chevyaker
Reg: 10-23-04
11-03-05 01:37 PM - Post#664218
    In response to
You solved it David. It is a 37 engine because the serial number is next to fuel pump rather than being behind the distributor. The block also has two bolts holding down the distributor which was changed to one bolt in 39'. The coil, air cleaner, carb and valve cover are not stock 216 parts. The car was originally black (paint 900) which is better than most of the drab colours they used.
greyoneca
Reg: 11-03-05
11-04-05 11:04 AM - Post#664219
    In response to 39Chevyaker
If I understand you all my engine is a 1937 216 - 224 mixture. The distributor sleeve has a place for two bolts but my distributor is held down by only one bolt, towards the back and only has one bolt hole. I will try to attache some pictures, in all likelyhood will mess it up so please tell me how to post pictures.
Greyoneca
39Chevyaker
Reg: 10-23-04
11-04-05 03:02 PM - Post#664220
Bob, you can't attach pics - they have to exist on a web server. Email them to me and I will post to my web server and reply with the link.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
11-04-05 06:16 PM - Post#664221
I would suspect that you may have a 1939 Arrow engine.The 1298992 engine number falls into the Info. from David for the Walkerville 1939 numbers-1288953 thru 1305600.The engine number location may have been different for the Canadian 224 engine.The casting and date numbers are also on the top of the head under the valve cover.The casting numbers from the intake and exhaust manifolds also would be helpful.
Anonymous
11-05-05 02:27 AM - Post#664222
Gene, the Canadian build plate quotes the original engine # as fitted in the Oshawa or Regina Plants, and in this case there was at one stage a 224 unit. However he has a 1937 engine now, # 96381. It does get confusing!
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
11-05-05 05:11 AM - Post#664223
    In response to
At one time I had more 224 information but can not find it now....What years was the 224 produced?Was there an "Arrow" model in 1937 and 1938??
I have a picture of a 1938 Pontiac sedan delivery - a 1938 Chevrolet body with an ugly version of a 1938 Pontiac front end grafted on.I seem to recall seing a sedan version many years ago.I am familar with the 1939 Arrow version as it used the Chevrolet A body and there were few changes.
It did find a site for these cars but can't find it now.
39Chevyaker
Reg: 10-23-04
11-06-05 09:43 AM - Post#664224
The Arrow was produced from 39-42 and was called the 22 or series 2200. GM Canada wanted to fill a price point and took the Master 85 and changed the sheetmetal forward of the firewall. The front end sheet metal is unique for this car because of the short wheelbase 112". Everything else is Chevrolet except for center dash trim, hubcaps, bumper and taillight emblems.
The 224 was available on the 37-38 model 26 and 39 model 25. The CDN 39 model 25 was the US Pontiac model 25 body (115")with a 224 (3 9/16" bore) valve in head engine. The parts book shows the 224 uses the same head 838751 and engine gasket set as the 216 for all years.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
11-06-05 04:14 PM - Post#664225
Intresting...The 1937-38 25 was the regular US Pontiac and it had a 222 cubic inch Pontiac engine rated at 85 HP - same as HP a US 216 Chevrolet.
Also from what you said did the 1939-40 Arrow have the Master 85 straight axle or coils?
Many yeas ago a friend bored his 1949 216 out to 3 9/16"...When a valve stuck and poked thru the cylinder wall we found the wall to be paper thin.The Pontiac version must have used a different casting.Do you know what HP the 224 was rated at?
39Chevyaker
Reg: 10-23-04
11-06-05 07:27 PM - Post#664226
The 39/40 Arrow used the Chev Master 85 JB/KB chassis (straight axle), running gear and body (except the front sheet metal). The firewall looks exactly like a 39 chev but it has a pair of mounts for the Pontiac horns and the center support for the alligator hood. The shop manual lists
224 89 BHP @ 3400 rpm 6.5 compression ratio
216 85 BHP @ 3200 rpm 6.25 compression ratio
All of the CDN Chev trucks had the 216 and all of the CDN GMC trucks came with the 224.
Anonymous
11-07-05 08:35 AM - Post#664227
Because it is all so confusing I have raided my database and uplifted a partial file. This has 1937-42 Canadian Chevrolet car & truck, Maple Leaf and Chev-based GMC trucks and Chev-based Pontiacs and shows the engine types as used plus serials. I have included known Regina vehicles and Pontiacs and GMCs as they are so rare!
http://clubs.hemmings.com/clubsites/chevytalk/37-42canadian.htm
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
11-07-05 05:13 PM - Post#664228
    In response to
That indiactes that some Arrows used a 216 and the DeLuxe used a 224.....Great list
Anonymous
1930 REGINA CAR
11-10-05 12:54 AM - Post#664229
Echoing the 1912-28 Forum, I have decided to put in here interesting Canadian Chev/GMC/Maple Leaf/Pontiac information.
This data is off a very rare Regina car:
GENERAL MOTORS
of CANADA Limited
MADE IN [ MAPLE LEAF] CANADA
OSHAWA WALKERVILLE REGINA
MODEL SERIAL NO
UNIVERSAL 458639
ENGINE NO 269801
FISHER BODY
BUILT BY
GENERAL MOTORS OF CANADA LTD. OSHAWA
CORRESPONDENCE PERTAINING TO THE
BODY MUST BEAR THESE NUMBERS
JOB NO. 30557
BODY NO. CK 227 R
Note the 'CK and 'R'!! Now, the 'R' suffix indicates presumably 'Regina Plant'..now we know that this ia Regina car because the serial # fits into the Regina series:
# 457001 to 462438
However what does 'CK mean? In 1928 Oshawa used 'K' for some bodies, but I suspect that it means 'Completely Knocked [down]'. Regina did not have a body facility in 1929-30, and 1931 when it was open but it did in 1937-41 after it re-opened for the second time [note opened once, closed, re-opened, closed, then re-opened, then closed for good]. All bodies were imported it seems as components from Oshawa and then assembled.
Anonymous
Re: 1930 REGINA CAR
11-10-05 11:39 AM - Post#664230
    In response to
A 1930 Oshawa - built car has just turned up..original engine and all! However the casting date is M-17-9, with M for December, so they missed out 'I' it seems. There is also the mysterous '1-H' casting next to the bowtie. I have conjected that this indicates Hamilton Foundry but we do not know! The jury is still out on whether GM of Canada assembled 1930 Model passenger cars in Walkerville Plant, as per the trucks from 1929-31, alongside engines. Trucks reverted to Oshawa in 1932 MY as Regina, Sask. Plant closed for the second time in August 1930. That said, Chevrolet Heavy Duty trucks, pre-Maple Leaf marque intro'd. 1933 were probably assembled in an ex-Fisher Body Plant in Walkerville near the truck and bus cab and body Plant. Chevrolet HD were based on GMC chassis with Chevy engines and debuted on July 1 1930. The US had no direct equivalent, although Canada did not get the LS trucks.
Anonymous
Re: 1930 OSHAWA CAR ...see previous posting
11-11-05 03:55 AM - Post#664231
    In response to
This is the aforementioned '30 AD Roadster but which body style is it? Sport Roadster or Super Sport Roadster? Where would the body plate be on an open US car? On the passenger seat or on the floor or dash?
Royer
Royer
Reg: 09-25-01
Re: 1930 REGINA CAR
11-11-05 04:35 AM - Post#664232
    In response to
On a US-built open body style, the plate is SUPPOSED to be on the right side of the seat frame according to a Krause Publications reference I have.
Royer
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
11-11-05 09:41 AM - Post#664233
    In response to
There were two roadsters built in 1930.A 2 passenger (no rumble seat) job with steel disc wheels and a 4 passenger Sport roadster with a rumble seat and wire wheels.The car appears to be a Sport roadster.
The serial numbers on US roadsters were in a different location I believe and the did not have a Fisher body - they had a Chevrolet body.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
11-11-05 01:20 PM - Post#664234
From a 1930 expert "the roadster and phaeton bodies were made by Chevrolet and did not have a body style/number ID plate.The serial number is on the passenger side (right) front seat kick-up"..JYD..this is for US cars.
37Chev4door
Loc: Alberta, Canada
Reg: 02-04-06
02-04-06 05:00 PM - Post#664235
Not to add to the confussion but... I would like to find out more about my recently acquired 37 Chev 4 door. I am not sure if it is a Master or Master Deluxe. How can I tell? The plate states: 7-12-19N, Serial Number:721904547, Body style:1347, Engine:91225, Paint:701, and Trim: 205
Rodding my 37 Chev
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
02-04-06 05:15 PM - Post#664236
    In response to 37Chev4door
I do not see a 1347 body style???
The Master will have a solid front axle and leaf springs.The Master DeLuxe has enclosed coil spring independent front suspension.
David Hayward
Deceased RIP David
David Hayward
Loc: New Forest, UK
Reg: 04-10-99
02-05-06 02:32 AM - Post#664237
Your decode is as follows:
Model 7-12-19W ..I think it's a 'W' for 'Western Distribution', namely the Western District office in the Regina, Saskatchewan Plant that remained there after closure of assembly faciliites around August 15 1932, and then re-opned December 1937 for 1938 MY.
Serial: 7121904547
Engine: 91225
Body Serial: 1347
Trim: 205
Paint: 701
Note the body style is 1219...or Fisher Job No. 1219, a 4-door 5-passenger sedan with Trunk, in the Master or Maitresse Seroes 1200.
Production commenced at Oshawa, Ontario November 6 1936, and finished October 1938. Serials ran # 712XX0001 to 712XX15743. Engines:
[R]64201
37Chev4door
Reg: 02-04-06
02-05-06 08:07 PM - Post#664238
I'll have to check the plate again and see if I have the body style correct. It is a solid axle with leaf springs, therefore a master. Thanks for this, very much appreciated.
Rodding my 37 Chev
Execution time: 0.087 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:20 PM
