Username Post: cement for fender extensions to fender        (Topic#5659)
brad_bb
brad_bb
Loc: Joliet, IL.
Reg: 07-13-01
11-12-01 07:20 AM - Post#40939
It's my day for questions. In need to bolt my fender extensions(splash pan sides) to my fenders. The assembly manual shows that cement was used. I remember it was kind of gray/green strip caulk like. 3M strip caulk is black, is there anything available closer to what was originally used?
If someone else can design it, I sure as heck can figure out how to fix it!
67SS427
67SS427
Loc: Lawrenceville, GA, USA
Reg: 05-26-01
Re: cement for fender extensions to fender
11-12-01 04:27 PM - Post#40940
    In response to brad_bb
You can also buy the 3M strip caulk in gray, if that's what you'd like to use. You may be right about the cement or caulking but I've never noticed it before on the 55 front fender extensions and never used anything there.
Anonymous
11-12-01 04:49 PM - Post#40941
    In response to 67SS427
Hi Brad,
The adhesive you are interested in was used to prevent "road splash" from seaping from the seam in the front fender.
45 years later, any seam sealant may be used. I have never met a judge who made a statement about this sealant.
So, you have many options. The good news is that today's materials are certainly better than what was used "way back then".
I would recommend a seam sealant - although I prefer 3M products - everyone seems (no pun intended) to have their favorite.
Oliver J. Giorgi
Chevytalk.com Moderator
Member #409
11-12-01 04:52 PM - Post#40942
    In response to
Never seen one without the caulking.
I thought all the caulking was gray, not black, good to know if it's ever needed that way.
The caulking isn't going to do a lot, except that when you drive it in the rain there will be a leak there, and you'll get a muddy streak. I guess some surface rust could form in the joint, but you should have paint on that if you've taken it apart.
Anonymous
11-13-01 05:18 AM - Post#40943
    In response to Rick_L
Yes guy's, 3M makes the caulking in gray, white and black., Any good 3M store has it and some dealerships also carry it.
Smokey
Chevytalk.com moderator:
55-57 Chevrolet
65-66 Chevrolet
67-69 Chevrolet
1st and 4th Gen Camaro
ChevyTalk Western Regional at Pomona Super Chevy Show
March 15-17 2002 Pomona, California
[This message has been edited by smokey (edited 11-13-2001).]
brad_bb
brad_bb
Loc: Joliet, IL.
Reg: 07-13-01
11-15-01 04:51 AM - Post#40944
    In response to
I'm being told by my local autobody supply store that 3M isn't making it in grey anymore. I guess I will try to find a real thick seam sealer in light grey.
brad_bb
brad_bb
Loc: Joliet, IL.
Reg: 07-13-01
11-29-01 05:20 AM - Post#40945
What I ended up using is 3/16 diameter rope caulk from Menards. It's off white in color. It says that it never hardens or dries out. Menards basically sells it for use on windows, but it should work just fine in this application, to keep water from collecting in this seam. As it turns out, 3M strip caulk is only available in black anymore.
[This message has been edited by brad_bb (edited 11-29-2001).]
Execution time: 0.143 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:22 PM
