Username Post: 1936 chevy master deluxe coupe doors        (Topic#376284)
Mike7231
Loc: Bardstown, KY
Reg: 06-08-18
01-25-25 07:57 AM - Post#2877369
I'm looking at a '36 Chevy Master Deluxe Coupe to restore that's about at my level to restore. Looks like a driver's side door would probably be easier to replace, than to repair, at least for me. Maybe both doors. Any ideas as to where I might find doors close to KY?
Thanks in advance..
1971BB427
Loc: Portland,Or
Reg: 12-06-09
01-25-25 08:58 AM - Post#2877373
    In response to Mike7231
Doors will be tough to find anywhere in the US! I think I'd plan on fixing the existing doors first.
1969 Suburban 2wd 350
1939 Chevy pass. coupe 350/700R4
1937 Austin gasser 327/TH350
Mike Boteler
Loc: Maryland
Reg: 09-11-17
02-12-25 07:33 PM - Post#2877837
I agree, find a good metal fabricator in your area and have them repaired...the chances of you finding Coupe doors in better shape will be slim to none.
Mike B
1971BB427
Loc: Portland,Or
Reg: 12-06-09
02-15-25 10:23 AM - Post#2877886
    In response to Mike Boteler
Seems like I recall someone buying early VW Bug door repair skins and using them to repair early Chevy doors? They're really cheap at around $100 and have similar contours.
Considering what I found when I bought lower door repair skins and inside door frame pieces and had such a bad fit, I'd never buy lower door patch panels again. Those I got from Chevs of the 40's were 1/4" too long inside and out, so I had to cut the inner panels in half and cut out the 1/4" then weld them back together. Outside I just cut it off one end to avoid a center weld seam.
Execution time: 0.413 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:08 PM
