Username Post: Heater Shut Off Valve        (Topic#376279)
Dave in VA
Dave in VA
Loc: SW Virginia, USA
Reg: 03-11-18
01-23-25 10:25 AM - Post#2877325
Mine is on the top hose, the one from the heat valve to the tstat housing. Is this the return? Deluxe heater.
If so, my plan is to choke that valve down to slow the flow thru the system to extract more heat out of the coil. It doesn't blow very warm at 27*...
"Knowledge is Good" -- Emil Faber
U S Navy MM2 1970-75 USS Canisteo AO-99, USS Miller DE-1091 (The Champagne of Ships)
1950 Styleline Deluxe 2dr, mostly stock, driver quality...new to me 3/18
2017 Silverado LTZ 6.2
2020 Blazer Premier
Edited by Dave in VA on 01-23-25 10:25 AM. Reason for edit: No reason given.
01-23-25 11:41 AM - Post#2877327
    In response to Dave in VA
Usually the return is the one back to the water pump.
drtyler
Loc: Georgia
Reg: 05-06-10
01-23-25 01:51 PM - Post#2877330
The water is a certain temp, whether its flowing or not. Wouldn't the heater core & water inside cool off quicker if the flow is reduced?
What is your thermostat temp?
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
01-23-25 02:10 PM - Post#2877331
This is the hose routing for the 49-50 Air Flow Heater (51-52 would be the same). I would think choking the flow would reduce the amount of hot water making it to the heater core. My thought is that you have a thermostat issue. When the heater was installed, it was done in conjuction with changing out the theromstat to a 180ºF unit that was furnished with the accessory heater installation kit.
Attachment: 1949-50_Air-Flow_Heater_Cable_Routing.jpeg (382.27 KB) 67 View(s)
Attachment: 1949-50_Air_Flow_Heater_Hose_Lengths.jpeg (228.45 KB) 76 View(s)
1951 Fleetline Preservation
'51 Fleetline DeLuxe, POWERglide 2-DR (Fathom Green)
'53 6500 Dump Bed (Faded Red)
'50 Styleline DeLuxe 4-DR (Mist Green)
53sd
Reg: 12-08-08
01-23-25 03:11 PM - Post#2877333
The hot coolant comes from/Out the hose by the thermostat
You want that hose to go to the bottom of the heater core
This will fill the core completely for the best heat production
Slowing down the fluid is not going in the right direction
The core might be scaled up inside
Dave in VA
Dave in VA
Reg: 03-11-18
01-23-25 04:30 PM - Post#2877334
    In response to 53sd
I guess that my thinking was backwards. Everything is hooked up as illustrated in RAM's drawings. The T-stat is 180.
Scale in the heater core is a good possibility. I've looked at the front of the core with a snake camera, and it appears to be free of debris.
The heater blows warm, at best.
2020 Blazer Premier
02-02-25 09:54 AM - Post#2877576
what is your engine temp? you may need a hotter stat.
Dave in VA
Dave in VA
Reg: 03-11-18
02-02-25 04:13 PM - Post#2877592
    In response to bobb
This is where the needle sits during normal operation. Just on top of the middle mark. If I stop and let it idle, it will rise a little bit. It's never got to the hot mark or overheated...
Attachment: speedo.png (1.57 MB) 21 View(s)
2020 Blazer Premier
Edited by Dave in VA on 02-02-25 04:18 PM. Reason for edit: No reason given.
my69
my69
Loc: Ct,USA
Reg: 04-19-03
02-04-25 03:28 PM - Post#2877629
That is normal looking to me, both of my 53 235s temp gauge is right there. It does climb while sitting at a light, but once you start moving again , the needle sits just above half.
53 210 4 door 235/PG
53 Bel-Air Sport Coupe
68 Impala SS Convertible 327/TH400
Edited by my69 on 02-04-25 03:29 PM. Reason for edit: No reason given.
53sd
Reg: 12-08-08
02-04-25 06:13 PM - Post#2877631
    In response to my69
Nice dash pad! Home brewed?
Dave in VA
Dave in VA
Reg: 03-11-18
02-05-25 05:41 AM - Post#2877640
    In response to 53sd
It was done by a previous owner. Probably when the interior was done...
Attachment: 4.jpg (127.29 KB) 14 View(s)
2020 Blazer Premier
RAM_51
RAM_51
Reg: 12-28-02
02-06-25 10:40 AM - Post#2877674
You mentioned you are running the recommended higher tempurature thermostat. I wonder if you are also using a pressure cap on the radiator.
Dave in VA
Dave in VA
Reg: 03-11-18
02-07-25 07:11 AM - Post#2877692
    In response to RAM_51
7lb, I believe...
2020 Blazer Premier
Execution time: 0.52 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:15 AM
