Username Post: ZZ427        (Topic#376277)
Jwhite
Loc: Edmonton, Canada
Reg: 01-18-25
01-22-25 05:01 PM - Post#2877318
Hi Folks, I'm just looking for anyone that has installed a zz427 in a 1966 biscayne,belair or impala. What little issues will i run into?
All tips will be greatly appreciated.
Thank you.
toro455
toro455
Loc: Western NY
Reg: 06-15-02
01-22-25 08:32 PM - Post#2877320
    In response to Jwhite
I have not installed a zz427 but the likely issues I can think of, I suspect, would be like installing any BBC in a car which didn't have one...assuming it didn't originally have one.
Some specific things I can think of are:
-The oil pan on the B-Body can be close to oil pans so if the zz427 comes with a generic-fit pan it might not work in the B-Body
-Radiator and shroud are different.
-Radiator spacer is likely different.
-You need a combination of motor mounts and engine stands which are intended for BBC to be certain the engine is at the correct height.
-Cars with PS are extremely tight to one header tube on the driver side. I don't know if you plan to use headers but if the heads on the zz427 are different the fit might change??
-Is the height of the intake different? You may want to verify air cleaner to hood clearance.
-If the valve covers are cast will accessories like the AC compressor fit over the valve cover on the passenger side?
01-23-25 07:00 AM - Post#2877322
front drive
Execution time: 0.867 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:08 PM
