Username Post: Looking for shift bushings for linkage at transmission        (Topic#376274)
data89
Reg: 01-22-23
01-21-25 09:46 AM - Post#2877296
1969 C10 step side. I'm looking for the shift bushings where they connect down by the transmission. Without removing them to match up to pictures, all my searches on the many parts sites seem to show different. Does anyone have good pictures of the bushings, or part numbers so I can order with confidence?
gcrkfrd
"7th Year" Platinum Supporting Member
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
01-22-25 09:45 AM - Post#2877313
    In response to data89
I found mine in the Help stuff at AZ, for late model Fords with man. transmission. It was an assortment, of plastic bushings with washer faces, and two of them worked.
1952 Styleline Sedan-62 235 PG
1967 C-20-2wd 327
1985 GMC 1500-2wd 4.3
The only running vehicles I own.
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
01-23-25 04:59 PM - Post#2877336
    In response to gcrkfrd
Did you try https://www.classicheartbeat.com/product-tag/67-72... You could call and ask Wes he knows all the tricks
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY C-10 Short Step 327
63 IMPALA 2/DR HRDTOP 327
Execution time: 0.438 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:32 PM
