Username Post: What Bearing size do I need?        (Topic#376267)
Joey1930
Loc: Breda, The Netherlands
Reg: 11-08-23
01-20-25 11:48 AM - Post#2877256
So I am rebuilding a 62 impala 235 to put in my 51 fleetline.
The crankshaft had great clearance on the mains and rod bearings and it looked great.
I still took it to the machine shop for a polish and have a thread tapped in for the harmonic balancer. The man of the machine shop (83 yo oldtimer) said I didn't need to go a bearing size larger since it was just a polish and the crankshaft was still in great condition.
Unfortunately it is hard to tell what size bearings are in there now. I can't really figure out the numbers written on the bearings. All it says is "GMMA" and various numbers.
I don't see "standard" or "0.10" stamped anywhere.
These are the sizes measured by the machine shop after the polish.
all rod bearings 2,3114173228
Main 1 2,6842519685
Main 2 2,7149606299
Main 3 2,7460629921
Main 4 2,7771653543
Hope somebody can tell me what size bearings I should go with so I can order new ones.
Thanks in advance
01-20-25 11:58 AM - Post#2877257
    In response to Joey1930
Have you checked the bearing clearances, see if you need bearings,or do they just look bad. All your crank journal sizes are correct for stock bearings, so what is the problem?
Edited by Shepherd on 01-20-25 12:42 PM. Reason for edit: No reason given.
Joey1930
Reg: 11-08-23
01-20-25 02:42 PM - Post#2877264
My bearings didn’t look so good anymore and number 4 was worn tappered.
But I guess I got the answer to my question if you tell me that the size is still stock.
What about the connecting rods?
01-20-25 03:58 PM - Post#2877269
As you posted, all the crank journal sizes meet the shop manual specs for a standard size crank. So std size bearings would be the right ones. Didn’t your machine shop tell you this?
Joey1930
Reg: 11-08-23
01-21-25 04:32 AM - Post#2877279
So at the machine shop they said that I could keep the same size bearing as I used because they didn’t have to grind off a lot.
But my confusion is that I couldn’t indentify the bearings that where mounted in the engine.
So I didn’t see std or 010.
But I alread Understand that they are all std
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
01-21-25 07:56 AM - Post#2877291
Here is a webpage that might be able to help you with other 1962 235 engine particulars:
LINK:
https://www.gm.com/content/dam/company/n o_search/h...
1951 Fleetline Preservation
'51 Fleetline DeLuxe, POWERglide 2-DR (Fathom Green)
'53 6500 Dump Bed (Faded Red)
'50 Styleline DeLuxe 4-DR (Mist Green)
Execution time: 0.511 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:08 AM
