Member #51
01-19-25 12:35 PM - Post#2877221
A doctor friend of mine, who's dad bought him a 350hp SS in hi-school, recently bought this supposedly documented genuine 61 SS.
He sold the car to attend med school, and has wanted one ever since. Finally got one!
The original painted valve covers are in the trunk.
55 Shaker
Loc: north central IL.
Reg: 03-13-06
01-19-25 01:59 PM - Post#2877223
I like it !!!!!
The older I get, the more dangerous, I am !!!! |
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
01-20-25 03:22 AM - Post#2877234
In response to 55 Shaker
Real SS or not, it’s a well done 61 Tom.
63 Pontiac Parisienne Sport Coupe(CDN Chev mechanically (409, 4 speed),1998 Silverado Reg Cab 4WD, 62 Bel Air SC (sold), 59 El Camino (sold), 62 Bel Air SC(sold), 63 SWC Vette (sold),
Member #2194
ss3964spd
Loc: Fairfax, Va
Reg: 12-21-00
01-20-25 05:36 AM - Post#2877236
In response to DonSSDD
Wow, that's pretty nice indeed.
Dan
If I recall correctly my memory is excellent. My ability to access it is not. |
dgstarr
Loc: Portland, OR
Reg: 04-16-13
01-20-25 09:58 AM - Post#2877251
In response to ss3964spd
The power steering pump is not correct.
Edited by dgstarr on 01-20-25 10:00 AM. Reason for edit: No reason given.
Member #51
01-20-25 10:18 AM - Post#2877252
In response to dgstarr
SOOOOOOOOOOO, does that mean you would kick it out of the garage into the street and put a sign on the windshield that says: FREE TO A GOOD HOME?
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
01-20-25 01:25 PM - Post#2877260
look close the steering box is updated.
Carl1962
Loc: Bungendore Australia
Reg: 04-01-10
01-20-25 06:23 PM - Post#2877273
In response to turbo38s10
If you post a photo of that liddle biddy cowl tag, we'll see if it's an SS.
Cheers, Carl.
1962 Anniversary Gold SS Impala Sports Coupe
1962 Anniversary Gold Impala Register
327
Loc: Ontario , Canada
Reg: 02-09-21
01-21-25 06:05 PM - Post#2877308
In response to Carl1962
:cool :
Member #51
01-29-25 03:26 PM - Post#2877494
That is EXACTLY correct. It is an add-on aftermarket PS setup. The original steering gear box has been replaced with with a later PS system gear box. Personally, I think it is a nice upgrade.
More pictures of my friends 61 SS.
Member #51
01-29-25 03:29 PM - Post#2877495
I am NOT a 58-61 Tripower expert. But this does not look like the linkage that I have seen on factory setups for the front-rear carb linkage.
Who can give information on this linkage vs factory correct linkage?
Sting Ray
"19th Year" Silver Supporting Member
Loc: Westwood Hills, Kansas
Reg: 02-19-05
01-29-25 08:05 PM - Post#2877499
Wow, what a car!
Bleeds Chevy Orange
1955 Bel Air hardtop, 327, 4-spd, tilt front end
1964 Corvette two top convert, 327, 4-spd
1967 El Camino, 427, 4-spd
2022 Corvette coupe, Arctic white, red stripes, 3LT Morello Napa leather |
japete92
Loc: No. Virginia
Reg: 01-18-13
01-30-25 07:09 AM - Post#2877505
Here's a clue:
https://www.chevytalk.org/fusionbb/showpost.php?po...
Perhaps the '61 Shop Manual?
Here's some more poop:
https://www.carburetor-blog.com/knowledge-base/roc...
Pete
Edited by japete92 on 01-30-25 07:32 AM. Reason for edit: No reason given.
DonSSDD
Reg: 08-21-01
01-30-25 10:42 AM - Post#2877508
In response to japete92
Jens had lots of posts on this with the original setup, it had that vacuum pod on the front driver side on the original setups. The new way to do them is the progressive linkage, I don’t think it has that vacuum pod. None of his posts that I found had pictures still there.
Member #2194
Member #51
01-30-25 12:43 PM - Post#2877515
Correct, my friends 61 has some kind of progressive linkage between the center and front/rear carbs, which APPEARS to be a better setup. But NOT factory.
There is a non-functional vacuum pod on the front carb (only serves for looks).
Once the air cleaner is installed the linkage cannot be seen and the vac pod is not visible to be non-functional.
So, in my opinion, it seems that the functionality is better than the factory vacuum linkage. I like it.
I was just curious what the factory setup should look like.
327
Reg: 02-09-21
02-02-25 04:08 PM - Post#2877589
:cool : :cool : :cool :
Member #51
02-04-25 08:20 AM - Post#2877624
In response to 327
More pictures of my friends 61 SS (and our 56 with FI).
Member #51
02-04-25 08:21 AM - Post#2877625
Dave_Neiling
Loc: Custar, Ohio United State...
Reg: 12-10-01
02-05-25 08:44 AM - Post#2877647
Wow beauties both only thing that is incorrect on the 61 is the SS cars came with 1 inch Whitewalls.
Chevrobert
Loc: Braintree, Ma. USA
Reg: 06-14-08
02-05-25 11:15 AM - Post#2877648
Color Me Green with Envy...,
Two Magnificent Cars!!
gkralik3645
Loc: omaha
Reg: 12-05-13
02-06-25 07:44 AM - Post#2877670
In 1992 when I was first looking for a car, I found a 61, I think it was an Impala bubble top, with a 348 and a 4 speed. I could have bought it for $3,000. But it was in pieces and I had absolutely no way to haul it to my house. Unfortunately I only had a one car garage at the time. I sure wish I could go back now and I would drag it home.
George
327
Reg: 02-09-21
02-07-25 06:01 AM - Post#2877689
DZAUTO .... :cool :
