Username Post: 1946 Chevy Stylemaster Ignition switch        (Topic#376248)
Mr49Fleetline
Mr49Fleetline
Loc: Salinas Ca
Reg: 01-29-14
01-17-25 04:30 PM - Post#2877168
Ok Folks its been a minute since I've been here so thanks in advance for any and all help. Heres the situation, Doing a wire conversion to 12 volt and am now at the part where I wire the ignition switch. I've rewired my 49 chevy fleetline before but that switch had 3 connections for wires on the back and this 46 only has 2, aligned vertically when switch is installed in the car and looking at it from under the dash. Which pole is for what or does it matter. There is also an armored cable that goes to the coil. I connected gas gage wire to the top post and a wire from Ammeter to the Bottom post, both wires subject to repositioning if need be, the instructions of where to connect them ask for 3 wires to be connected, One to the ACC terminal, another to the battery terminal and another to ignition terminal.
Also Im still using the floor stomp button type starter
Again thanks for any and all help.
Common Sense Ain't common..Will Rogers
Mr49Fleetline
Mr49Fleetline
Loc: Salinas Ca
Reg: 01-29-14
01-25-25 06:55 AM - Post#2877366
    In response to Mr49Fleetline
I figured it out with the help of a YouTube channel creator.
Member #189 Moderator and "23rd Year" Platinum Supporting Member
01-27-25 12:57 PM - Post#2877453
Thats good.
29-41, 42-48, 49-54 Moderator
Execution time: 1.576 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:00 PM
