845frankm
Reg: 08-07-24
01-12-25 07:30 AM - Post#2877001
chevy 350 cylinder #1 140 #2 130 #3 140 #4 155 # 5 140 #6 140 #7 145 # 8 130 good or bad
01-12-25 09:16 AM - Post#2877003
In response to 845frankm
Looks ok. But maximum pressures are dependent on cam timing, compression ratio and cranking rpm.
01-12-25 10:30 AM - Post#2877005
the only reading that matters is the first jump of the needle. it may take a few tries to get the correct number.
01-13-25 03:45 AM - Post#2877026
In response to bobb
Was the throttle wide open during testing? #2 and #4 stick out little. Was it warm or cold?
Are you chasing a misfire?
'08 GMC Acadia 3.6L SLE
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
01-30-25 04:23 PM - Post#2877525
The only thing that I see is that 2,4, & 8 are not w/in 10% of each other (13psi)
Where ye be?
For me, at 4,670' in Western CO....those #s are fairly decent
