smithd7
Loc: Coburg,Oregon,U.S.A.
Reg: 11-07-01
01-08-25 12:15 PM - Post#2876894
2006 trailblazer my speedometer will go to zero then after the next start up it will be fine,then
later on it will go to zero again. Anyone have this
problem before?
'61 Impala HT,
'63 Nova SS convertible,'99 C-5 convertible, '72 GMC Sprint SP |
01-09-25 04:59 AM - Post#2876916
In response to smithd7
Just the speedo, rest of the gages ok?
smithd7
Reg: 11-07-01
01-09-25 02:32 PM - Post#2876930
Yes just the speedometer.
'61 Impala HT,
01-09-25 05:43 PM - Post#2876933
Wow. Easier to diagnose if it was the entire cluster. The step motor could be failing. Since it does come back to life, I would suspect a bad solder joint. Do you have a scanner that can read speed? You can hook it up and see live data. If it's continuous, the output sensor is good. A bad connection at the cluster will be hard to diagnose. There are companies that specialize on fixing instrument clusters.
'08 GMC Acadia 3.6L SLE
01-09-25 06:23 PM - Post#2876935
I was just going to post the same info, had the same problem with my 2003 TB, overall not a good vehicle.
Edited by Shepherd on 01-09-25 06:24 PM. Reason for edit: No reason given.
smithd7
Reg: 11-07-01
01-10-25 12:28 PM - Post#2876949
Thanks so much think I will take it to a electronics shop.
'61 Impala HT,
01-12-25 03:37 AM - Post#2876997
Please let us know how it's fixed. A picture would be nice if they find a bad solder joint. Looking at YouTube videos, even loose connections have been found.
