Username Post: Muncie 4 speed speedo cable?        (Topic#376204)
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
01-06-25 11:02 AM - Post#2876847
Hey guys will I need a new speedo cable when I go to install a Muncie 4 speed tranny?
55Brodie
Loc: Little River, SC
Reg: 12-26-15
01-06-25 12:01 PM - Post#2876849
    In response to Eth727
Not if the T-10 and Muncie both have the speedo connection on the same side. If the Muncie has a passenger side connection you may need a longer cable.
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
01-06-25 12:17 PM - Post#2876851
    In response to 55Brodie
It’s on the driver side . So I should be good then?
Dave_Neiling
Dave_Neiling
Loc: Custar, Ohio United State...
Reg: 12-10-01
01-06-25 01:08 PM - Post#2876852
yep should be good to go same cable. Passenger side does need the longer cable.
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
01-06-25 05:21 PM - Post#2876858
    In response to Dave_Neiling
Thanks guys
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
01-07-25 01:49 AM - Post#2876862
One thought about the speedo, may be a good idea to check the speedo gear in your transmission, just have a look at it- they are made of plastic, see if the teeth are not broken. Also, take a picture of the gear and count the teeth. If you find your speedometer is way off after you are driving the car, it’s good to know what’s in there if you need to get a new gear with more or less teeth to get your speedometer speed adjusted. Good time to get a new cable too if you didn’t replace it already.
63 Pontiac Parisienne Sport Coupe(CDN Chev mechanically (409, 4 speed),1998 Silverado Reg Cab 4WD, 62 Bel Air SC (sold), 59 El Camino (sold), 62 Bel Air SC(sold), 63 SWC Vette (sold),
Member #2194
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
01-07-25 07:24 AM - Post#2876865
    In response to DonSSDD
Putting on my 'Carnac the Magnificent' persona; I predict the next question is:
Why is my speedometer jumping back and forth and making a lot of noise?
Not being critical; just 'connecting' to those old enough to know who Carnac was.
Pete
62sedan
62sedan
Loc: Above the red Texas dirt
Reg: 08-12-02
01-07-25 01:03 PM - Post#2876869
    In response to japete92
Chuck
rcr3
Site Ambassador -"21st Year" Gold Supporting Member
rcr3
Loc: MANHEIM PA. U.S.A.
Reg: 11-24-02
01-08-25 03:59 AM - Post#2876886
'67 Camaro survivor
'06 Z71 Sierra Ex Cab
'37 Chevy cp.SOLD!!6/7/14
'73 Nova pro-street project
'17 Chevy Trax LT AWD
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
01-09-25 09:08 PM - Post#2876936
    In response to rcr3
I’m going to pull out the gear from my 3 speed Saginaw and stick it in the Muncie
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
01-24-25 12:16 PM - Post#2877352
So I installed the 4 speed Muncie and the speedo cable is not long enough. It’s too short. I need a new longer one between 4-5” longer
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
01-24-25 05:23 PM - Post#2877357
Cable connection on drivers side passenger side? Most Muncies are passenger side connection for speedometer.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp HT SS 409/482 stroker 5 spd
https://paulstensland.com
Dave_Neiling
Dave_Neiling
Reg: 12-10-01
01-25-25 06:18 AM - Post#2877362
    In response to pvs409
When you order your cable order is for a later car 66 on up thats when the cable was switched over to the passenger side.
DonSSDD
DonSSDD
Reg: 08-21-01
01-25-25 08:47 AM - Post#2877371
The cable in the 3 speed is obviously shorter than the one in the 4 speed, transmission is shorter? Should be easy to find a bit longer cable. A 4 speed cable driver side hookup is 63 inches, how long is yours?
Member #2194
Execution time: 2.023 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:45 PM
