Username Post: Which Brake fluid should I use        (Topic#376195)
Ducktruck
Reg: 12-28-24
01-03-25 01:03 PM - Post#2876770
UPDATE, Thanks guys. Just the information I was needing.
Got a 65 with drum all the way around. Do I use DOT 3 or do I need to go to DOT 2 fluid? I did a search but couldn't find the answer.
Edited by Ducktruck on 01-06-25 02:54 PM. Reason for edit: Updated
01-03-25 02:55 PM - Post#2876776
    In response to Ducktruck
Dot 3 or 4.
Senior Moderator
01-04-25 08:53 AM - Post#2876791
  • Shepherd Said:
Dot 3 or 4.
Agreed. I didn't even think DOT 2 was still a thing. That's a mineral oil based fluid that is absolutely not compatible with DOT 3 or DOT 4 which are glycol based. Go with the DOT 3 or DOT 4, which are compatible with each other though DOT 4 has a slightly higher boiling point.
And whatever you do, keep it away from your painted surfaces; it'll damage paint quickly.
93 C3500 dually / 94 C1500 ecsb / 06 Silverado SS / 06 300C SRT8
01-05-25 09:32 AM - Post#2876820
i use dot 5 silicone fluid in hopes it wont corrode as easy. not for use in anti lock brakes.
01-05-25 10:03 AM - Post#2876823
    In response to bobb
Only issue with dot 5 is the entire brake system must be free of dot 3 or 4, 5 cannot mix. We only use 5 in our shop with a new system installed
Execution time: 2.822 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:40 PM
