Doufus
Reg: 12-04-19
12-11-24 05:33 PM - Post#2876212
Working on a 60 Impala and need to replace the radiator. I have had good luck with Cold Case on other cars, so I wanted to use one of theirs, however they do not list one for a 60. I called and they said that a 61 may fit. Has anyone used a 61 in a 60? If so, how did it fit? Any problems?
Thanks!
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
12-12-24 08:41 AM - Post#2876224
In response to Doufus
FWIW, rock auto list the same part number for a 60 and 61. Check other vendors to see if they agree like hubbards etc.
63 Pontiac Parisienne Sport Coupe(CDN Chev mechanically (409, 4 speed),1998 Silverado Reg Cab 4WD, 62 Bel Air SC (sold), 59 El Camino (sold), 62 Bel Air SC(sold), 63 SWC Vette (sold),
Member #2194
Doufus
Reg: 12-04-19
12-12-24 10:14 AM - Post#2876226
In response to DonSSDD
Thanks!. I'll do some more checking. ECP says that if you use a mechanical fan with theirs then you have to use a 65 to 68 fan shroud. That makes no sense to me!
DonSSDD
Reg: 08-21-01
12-12-24 03:33 PM - Post#2876233
They must have a weird rad if a 65-68 shroud works- or they don’t know what they are talking about? If you have a small block, use a small block shroud for a 59-63. Check out Show Cars in MN for pics of shrouds and rads too.
Member #2194
Doufus
Reg: 12-04-19
12-12-24 04:50 PM - Post#2876238
I didn't understand either. Talked to Cold Case again today, about 99% sure theirs will work, they have a black alum. one now that looks really nice. About ready to order lots from Show Cars, dealt with them before, really good to work with.
Thanks!
Doufus
Reg: 12-04-19
12-12-24 04:52 PM - Post#2876239
Forgot to add, it is a 348 tri power. I also have a 59 small block shroud in addition to the one for the 348.
Edited by Doufus on 12-12-24 04:53 PM. Reason for edit: No reason given.
DonSSDD
Reg: 08-21-01
12-13-24 04:31 AM - Post#2876240
The short 348 shroud, definitely different than the 65 up shrouds!! Check the mounting bolt holes on the CC one, plus do you have a stock steering box? If you have changed out to a 605 or other, be careful- the rad may need a notch to clear it. Show Cars sells those I think- I have stock PS in my 409 so no expert in the aftermarket PS.
Member #2194
Dave_Neiling
Loc: Custar, Ohio United State...
Reg: 12-10-01
12-15-24 10:11 AM - Post#2876294
Cant you recore your original or do you just want to replace it?
Doufus
Reg: 12-04-19
12-17-24 04:41 PM - Post#2876333
In response to Dave_Neiling
Radiator has a couple of spots that look like they need repair. Owner would rather spend a little more and go with an aluminum one. Repairs have been running around $ 200.00, got the Cold Case for $339.00.
Doufus
Reg: 12-04-19
12-19-24 06:55 PM - Post#2876383
Got the Cold Case radiator today. Test fit, fits ok, lower bolt holes will need a little massaging. Biggest problem is the lower outlet is not in the same spot as the one I removed, about 2" more to the center. Will have to find a hose for it.
Actually, the biggest problem is for some reason I thought they were made in the USA, made in China sticker on the box. Kinda disappointed, but I have had good luck with them in other cars, so we'll see.
Dave_Neiling
Reg: 12-10-01
12-20-24 05:41 PM - Post#2876411
Hope it works out for you.
Doufus
Reg: 12-04-19
12-20-24 06:02 PM - Post#2876414
Thanks! Me too!
