Rapidronnie
Loc: MO
Reg: 11-26-24
11-29-24 05:24 AM - Post#2875987
I'm trying to figure out which wilwood 4 piston calipers will fit on my 55 with a 70 chevelle disc brake conversion. Stock chevelle 11" x 1" rotors. If anyone has any helpful info on this it would be appreciated.
11-29-24 08:53 PM - Post#2876012
In response to Rapidronnie
welcome to ct. if you have chevelle spindles i would be looking for chevelle calipers. if the rotors were adapted on it may not be easy.
55_FEVER
Loc: Abbotsford, B.C. Canada
Reg: 01-23-02
12-02-24 04:11 PM - Post#2876073
I went through this last year. If you have heidts drop spindles, then Wilwood sells adapters for their calipers. If not you need to buy their or compatible spindles. I’d recommend you call Earle at Williams Chassis Works. He knows these setups inside out and will steer you straight. I bought my setup from him and he was less money than Wilwood, even with their year end sale. Good luck
