Username Post: Tiny bubbles        (Topic#376013)
61ragtop
Loc: Langley B.C. Canada
Reg: 07-30-03
11-18-24 11:49 AM - Post#2875727
Hey everyone! I have a conv 61 impala that was painted in early 2000s. Not long after being sprayed it was wet sanded and polished.
Now years later I have small pin head sized bubbles that showed up that you can feel as well. They have not grown over the eye are at all. One spot is where the quarter meets the filler panel between the trunk and back window where the factory fills with lead that is still present. The other it on the top corner of the trunk lid.
What would cause this?
I am about to repaint the car and want to make sure this doesn’t happen again.
Hopefully this link works for pics I am new to this lol.
https://www.dropbox.com/scl/fo/jytl4aaniz0www 3njck...
Sting Ray
"19th Year" Silver Supporting Member
Sting Ray
Loc: Westwood Hills, Kansas
Reg: 02-19-05
11-18-24 02:37 PM - Post#2875730
    In response to 61ragtop
By chance was there ever a plastic cover on the car?
Bleeds Chevy Orange
1955 Bel Air hardtop, 327, 4-spd, tilt front end
1964 Corvette two top convert, 327, 4-spd
1967 El Camino, 427, 4-spd
2022 Corvette coupe, Arctic white, red stripes, 3LT Morello Napa leather
12-01-24 09:54 AM - Post#2876051
i have the same issue. i failed to dig deeper into it so i have no answer. i would get a sharp pick or razor and cut the bubble off to see if there is a rust root in there.
61ragtop
Reg: 07-30-03
12-01-24 10:31 AM - Post#2876053
    In response to Sting Ray
No plastic covers ever.
61ragtop
Reg: 07-30-03
12-01-24 10:32 AM - Post#2876054
    In response to bobb
Yes unfortunately I got a little eager and used a stripping wheel on the one spot where the lead is. I will try a razor on the other spot on the trunk lid.
Execution time: 0.144 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:26 AM
