Username Post: Cooler        (Topic#375942)
Camaro 67 Antwerp
Reg: 06-23-24
11-04-24 08:28 AM - Post#2875334
Does anyone know what size and thread the connection between the automatic transmission and the cooler has? I have a 327 with powerglide transmission. I bought a new cooler and the connections fit but there is no ”bottom” in the holes so the pipe is still loose so i am looking for some kind of adapter like npt to screw into the cooler and the right hole in the other end for my oil pipe.
11-05-24 07:28 AM - Post#2875359
    In response to Camaro 67 Antwerp
hard lines are most likely inverted flare. the hole is probly npt pipe. you would need adapters.
Execution time: 0.815 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:51 AM
