tppower
Loc: Boise, ID
Reg: 09-11-23
10-09-24 11:29 PM - Post#2874543
Hi everyone, the rear quarter door panels on my 2 door bel air stick out as seen in these pictures.
https://imgur.com/a/XgF24Hp
there are no tack nails or anything to secure it to the B pillar. The screw in the picture is only on the driver side and was done at some point decades ago by the previous owner. Does anyone know a good way to fix this gap, either OEM or otherwise?
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
10-10-24 09:49 AM - Post#2874550
In response to tppower
Looks like the interior panel is missing the metal rails with nails - that use cardboard tacking strips on the edges of the door jamb.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp HT SS 409/482 stroker 5 spd
https://paulstensland.com
pvs409
Reg: 01-10-05
10-10-24 09:52 AM - Post#2874551
The round red windlace is supposed to be stapled to the cardboard tacking strips separately from the interior panel
tppower
Loc: Boise, ID
Reg: 09-11-23
10-12-24 06:36 PM - Post#2874621
In response to pvs409
makes sense so it was installed wrong by the previous owner, can i buy that tack strip?
61ragtop
Loc: Langley B.C. Canada
Reg: 07-30-03
10-13-24 09:08 AM - Post#2874633
yes ciadellas carries them
pvs409
Reg: 01-10-05
10-13-24 09:59 AM - Post#2874637
Yes you can buy the tack strips but they are only sold as a set of 4 strips with nails( doors and rear 1/4s). Cars Inc sells them also.
You might be able to reuse originals ( I have some used ones).
Paul
pvs409
Reg: 01-10-05
10-13-24 10:05 AM - Post#2874638
When I look closer at your pictures I see nails on the interior panel - remove the windlace from interior panel and staple it to your cardboard tack strips ( if you have them on the door jamb??)
After windlace is stapled you pound with your hand the interior panel to the tack strips making sure to hit the tack strip with the nails
Paul
tppower
Loc: Boise, ID
Reg: 09-11-23
10-28-24 07:08 PM - Post#2875130
ill probably wait a bit then. I need new windlace as its torn at the top corner of the door.
pvs409
Reg: 01-10-05
10-28-24 08:11 PM - Post#2875136
You can buy vinyl windlace separately from Cars Inc in the correct color.
