Username Post: Hydroboost question        (Topic#375812)
995jim
995jim
Loc: Ohio
Reg: 12-17-06
10-08-24 09:32 AM - Post#2874508
Hi, any ideas what causes my newly installed hydroboost brake system resist on inital quick pump of the brakes ?
Fluid is at full level in ps pump and i assume it self bleeds with operation.
Thanks jim
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
65_Impala
Reg: 12-29-02
10-10-24 09:48 AM - Post#2874549
    In response to 995jim
Is its return line Teed with the power steering return line?
995jim
995jim
Loc: Ohio
Reg: 12-17-06
10-10-24 01:40 PM - Post#2874555
    In response to 65_Impala
yes, is there another option? I just followed the install in instructions
65_Impala
Reg: 12-29-02
10-11-24 10:16 AM - Post#2874574
You need a reservoir with 2 return fittings.
995jim
995jim
Loc: Ohio
Reg: 12-17-06
10-11-24 02:01 PM - Post#2874577
any ideas on a reservoir that fits a 65 impala bracketry?
thanks jim
995jim
995jim
Loc: Ohio
Reg: 12-17-06
10-11-24 02:03 PM - Post#2874578
Or do I just tig weld a separate port in the back of the pump?
65_Impala
Reg: 12-29-02
10-12-24 06:22 AM - Post#2874596
Either could work. A pump from a 80's or 90's pickup with hydraboost might work or be able to be made to work, I'm not sure.
10-12-24 10:35 AM - Post#2874605
i dont see why the tee wont work. i would run the line straight into the top of the res to find out before doing all the work to get a 2 line reservoir.
10-13-24 06:20 AM - Post#2874625
Thanks jim
Usually T'ing into the return line will cause noise. The symptom doesn't sound like that's the problem. More like a brake issue instead of hydraboost. Maybe a caliper sticking or binding pedal link.
995jim
995jim
Loc: Ohio
Reg: 12-17-06
10-13-24 04:14 PM - Post#2874659
    In response to bobb
I took the car out today and hit the brake hard and what it did was pushed back out at my foot for a split second then went back down. Does that give any other clues? Normal foot pedal braking is fine.
thanks jim
Edited by 995jim on 10-13-24 04:15 PM. Reason for edit: No reason given.
Execution time: 1.592 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:04 PM
