995jim
Loc: Ohio
Reg: 12-17-06
10-06-24 03:42 PM - Post#2874460
hello, just looking for comments on this plug. engine is a 468, 6:71 blower, 8:1 comp, #8 boost (2)- 750 holley carbs 5.5power valve, 67main jets. To me the plug looks good but I would like some input as to whether or not its a little rich or to lean for a blower . Im new to a blower motor.
thanks jim
Attachment: plug.jpg (173.74 KB) 102 View(s)
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ |
10-09-24 07:29 AM - Post#2874529
In response to 995jim
looks ok to me. you probly need lots of initial timing and not so much total centrifugal timing. i use an af monitor to tune wot, cruise and power valve values. idle and off idle i just go by how it drives. if it goes too lean at wot you could get into lots of trouble. i use big plug gaps too. that air pump makes it a whole different animal.
995jim
Loc: Ohio
Reg: 12-17-06
10-10-24 12:41 PM - Post#2874556
In response to bobb
All I have ever read was small gaps but your using long gap. Im at about .030
Magnetocheck
Loc: Charlotte, NC, USA
Reg: 09-05-22
10-10-24 02:34 PM - Post#2874560
Agree - looks pretty go to me but I don’t have any experience with boosted engines. Timing mark looks good. Get a real bright light and see if you can see down the space to view most of the porcelain. You may not be able to see the combustion line w/o cutting off the threads. Line should be almost down at the junction Make sure you check after a high speed run with minimal to no idling as that will soot them up
Bob
'65 Impala SS 396 Convertible
Member, National Impala Association
--It's weird being the same age as old people! |
10-11-24 07:17 AM - Post#2874570
try it, it cant hurt.if you dont run at full power you wont know the difference. maybe like .045
grumpyvette
Performance Subject Matter Expert --
Loc: farmersville texas USA
Reg: 03-16-01
10-17-24 07:21 AM - Post#2874777
In response to bobb
Id really need a clearer photo to read the plug effectively, that picture looks like the plug was out of a car that had not been run in several days minimum.
post a clear picture of a plug you removed from a car that you ran briskly under load for several miles and I can get more info!
https://garage.grumpysperformance.com/index.php?th...
IF YOU CAN , YOU NEED BETTER TIRES AND YOUR SUSPENSION NEEDS MORE WORK!! |
