Username Post: Advice please, 50 Powerglide vacuum tube        (Topic#375792)
Loren S
Loren S
Loc: NW Ohio, Northern Michiga...
Reg: 08-02-17
10-05-24 07:42 AM - Post#2874428
Reinstalled engine and transmission after several years out for overhaul. Please advise where to hook up vacuum line from engine to transmission. The tube left over in my parts (see photo) does not appear to reach the only fitting I can find on the transmission (which is on the passenger side of the transmission). Any help is appreciated.
Attachment: IMG_5595.jpeg (3.73 MB) 71 View(s)
These are the "Good Ole Days:.
52_Belair
Loc: Canby, Oregon
Reg: 03-25-03
10-05-24 08:49 AM - Post#2874431
    In response to Loren S
I have never looked to see where the vacuum line hooks into the transmission on my '52 PG.
However it is connected to the manifold through a T fitting then goes down past the parking brake linkage then turns behind the oil pan heading to the passenger side of the engine.
Hope that helps some.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
10-05-24 09:29 AM - Post#2874434
I think these three 1950 Illustrations should explain the vacuum and oil lines on the early PowerGlide.
Attachment: 1950_PowerGlide_235_Left_Side___Vacuum_Line.jpg (2.52 MB) 77 View(s)
Attachment: 1950_PowerGlide_Oil_and_Modulator_lines.jpg (407.65 KB) 78 View(s)
Attachment: 1950_Chevrolet_PowerGlide_Engine_Oil_Lines.jpg (523.07 KB) 74 View(s)
1951 Fleetline Preservation
'51 Fleetline DeLuxe, POWERglide 2-DR (Fathom Green)
'53 6500 Dump Bed (Faded Red)
'50 Styleline DeLuxe 4-DR (Mist Green)
Loren S
Loren S
Reg: 08-02-17
10-05-24 12:09 PM - Post#2874436
    In response to RAM_51
Thanks for the responses guys....big help.
RAM_51
RAM_51
Reg: 12-28-02
10-05-24 01:38 PM - Post#2874438
I just remembered! I recently picked up a 73,000 mile, 1951 235 engine with PowerGlide trans and most lines still attached. Here is the manifold fitting on it.
Attachment: 1951_Fleetline_PowerGlide_Vacuum_Fitting.jpg (3.01 MB) 73 View(s)
10-05-24 03:56 PM - Post#2874440
Pg requires manifold vacuum from any source available. I know, obvious. Lol
52_Belair
Loc: Canby, Oregon
Reg: 03-25-03
10-06-24 05:57 PM - Post#2874465
A side question. If the early PG do not shift themselves what does the vacuum do?
RAM_51
RAM_51
Reg: 12-28-02
10-07-24 09:01 AM - Post#2874475
    In response to 52_Belair
PowerGlides do shift themselves when placed in DRIVE. If however, you wish to get a quicker start, you can shift the lever to LOW as you start, then shift to the DRIVE range as you gain speed.
What does the vacuum do? It operates the modulator which increases or decreases oil pressure as required. This is the way the 1950 Engineering Features Book states it.
"The purpose of the vacuum modulator is to impose additional resistive force on the pressure regulator valve to increase oil pressures when high torque is being transmitted. Also, it removes this force, reducing oil pressures when less torque is handled".
52_Belair
Loc: Canby, Oregon
Reg: 03-25-03
10-07-24 11:33 AM - Post#2874479
Hmmm, my understanding was the PG didn't automatically shift until 1953 and the torque converter is different pre '53 to provide more torque for starting in Drive.
My father told me the '52 didn't shift automatically. I have never heard or felt any sign of a gear change when starting in drive and have ridden in this car since it was 6 years old.
From Wikipedia:
The 1950 through 1952 Powerglide transmissions did not automatically shift between low and high (direct drive) which made for very sluggish take-offs and many drivers started in "Low" and shifted to "Drive" at about 30–40 mph (48–64 km/h). The 1953 and later units when in "Drive" started in low and automatically up shifted to high at a speed determined by the throttle opening. By the mid-1950s, more than half of all new Chevrolets were sold with Powerglide.
Edited by 52_Belair on 10-07-24 11:36 AM. Reason for edit: No reason given.
RAM_51
RAM_51
Reg: 12-28-02
10-07-24 12:14 PM - Post#2874481
Okay, let me restate this...there was no "shift" per se, or feeling of a definite "lurch" in the original PowerGlides but there were things going on inside the unit itself that reduced and increased power to the the drive train; the modulator and the vacuum modulator that was discussed and also stators that would lock and unlock. The engine had a tendency to rev higher without much appreciable increase in speed...but eventually things caught up to one another and the phrase "SLIP AND SLIDE WITH POWERGLIDE" was born. The transmission did not automatically shift to the LOW gear unless the driver did that manually. Later as you and wikipedia specify...the PowerGlide was redesigned to not only shift to low from a stand-still, but it was also redesigned to automatically down shift to low when accelerating aggressively...i.e. passing.
View the Jam Handy film below
value="transparent">
Toms50
Toms50
Loc: PA, USA
Reg: 06-08-16
10-07-24 03:43 PM - Post#2874487
Powerglide info
available as optional equipment on DeLuxe models only.
Hydraulic torque conversion
1953 Powerglide Shift patterns
52_Belair
Loc: Canby, Oregon
Reg: 03-25-03
10-08-24 09:44 AM - Post#2874509
Okay when I said it doesn't shift itself I meant the changing of gears ratios like in later transmissions.
I was aware that the torque convertor multiplies low end torque. I don't know anything about how the vacuum modulator works.
Cool video, I wish it would have talked about the vacuum operation in the transmission.
RAM_51
RAM_51
Reg: 12-28-02
10-08-24 06:50 PM - Post#2874525
There is another video called the "Velvet Glove" where, toward the end of the video, they compare acceleration against a manual transmission equipped Ford from a standing start. They mention that to get the edge required, the driver of the Chevrolet needs to really give the accelerator a good nudge to start. Doing that delivers higher oil pressure in the torque converter via the vacuum portion of the modulator valve. That's the way I understand it anyway. It gets things going quicker and acts sort of like a low without bringing the low gear cluster into play...in other words, without actually manually shifting to low to get the advantage and just using the torque converter portion of the transmission. Here is that video:
52_Belair
Loc: Canby, Oregon
Reg: 03-25-03
10-09-24 11:58 AM - Post#2874534
I just happened to see that video earlier today!
Execution time: 1.649 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:55 PM
