Username Post: Stock wheels and a spin-balancer?        (Topic#375769)
drew1987
drew1987
Loc: Western NY
Reg: 02-23-14
09-28-24 01:07 PM - Post#2874275
Hey!
I finally got a dynamic spin balancer and was going to balance my tires as they have a little shimmy. I was told a long time ago that becuase they are lug centric, the hub hole isn't true. I find this hard to believe. I DO have a vw style adapter I could in theory use, but I want to know from you guys how it has gone just using a cone in the center hole.
Thansk!
Drew
Andrew D. Carapella (Drew)
1950 Chevy Styleline Deluxe
1954 Chevy 3100
Various other "modern classics"
09-28-24 01:17 PM - Post#2874276
    In response to drew1987
My stock 51 wheels are hub centric. Mount one wheel see if it is in fact hub centric,.Lug
centric wheels need a special adapter for the wheel balancer.
Edited by Shepherd on 09-28-24 01:19 PM. Reason for edit: No reason given.
drew1987
drew1987
Loc: Western NY
Reg: 02-23-14
09-28-24 03:16 PM - Post#2874278
Thanks! Looks like the hole larger than the hub...
I do have the adapter but it looks a bit rinkydink... I would imagine - though I can be wrong - a wheel that has a hub hole larger than the hub on the car is still true to the hole, i cant imagine it's haphazardly manufactured unevenly?
I have to imagine to play that is natural to our front ends all but disappears with perfectly balanced wheels! Looking forward to that! Now to add power steering, go back to an I6, and install an overdrive transmission. And about 300lbs of sound deadening...
1954 Chevy 3100
09-28-24 04:19 PM - Post#2874281
Hard to tell how accurately machined they were back in the day. Using the cone adapter on the balancer spin a wheel and look for vertical runout, that will tell if the hole is in the center of the wheel.
ss3964spd
ss3964spd
Loc: Fairfax, Va
Reg: 12-21-00
09-29-24 07:00 AM - Post#2874288
I have read, and learned, the same thing, Drew, the stock wheels are lug centric, not hub centric. To be hub centric the wheel must fit snugly on the hub with no play between them.
Dan
09-29-24 12:05 PM - Post#2874291
    In response to ss3964spd
My stock wheels are mounted, hub centric on 11" GM rotors and a Camaro 10 bolt 8.5 rear, maybe that's why they are hub mounted,
drew1987
drew1987
Loc: Western NY
Reg: 02-23-14
09-29-24 12:17 PM - Post#2874292
Hmmmm. Good point on vertical run out. I’ll take a swing at this and report back. Might be a while. But glad to finally have a computer balancer
1954 Chevy 3100
"19th Year" Silver Supporting Member
10-01-24 06:08 AM - Post#2874330
When I was driving my '54 Chevy 3/4 ton truck, with split rims, my mechanic would jack up the front of my truck, bring an electrically driven "spinner" to the each tire, and spin the tire while it was on the truck. Somehow, and I never understood how, he then determined where the wheel weights needed to go.
1953 210 Convertible, 261 with dual Carter YF 966S carbs, P.S., Remote Bendix P.B. Booster.
10-01-24 06:25 AM - Post#2874332
I've seen that done, brakes not dragging, the heavy spot on the wheel rolls to the bottom, then weight is added 180 degrees opposite til the wheel does not rotate on it's own. Pretty crude.
drew1987
drew1987
Loc: Western NY
Reg: 02-23-14
10-01-24 07:52 AM - Post#2874336
rrausch did he have a gismo clamped on the rim? There was early dynamic balancers that worked like that!
Shepherd, thats actually how motorcycle tires were balanced in the day, I think....
here is a video I made some time ago about bubble balancing - there is an illustration early on that compared static vs dynamic balance. Sheds some light on this topic. Nevertheless I am SOOOOO glad to be done with bubble balancing haha https://youtu.be/C28rtJqvPl4
1954 Chevy 3100
10-03-24 07:58 PM - Post#2874403
Drew, I don't remember. This happened 30 years ago. The shop was a Bee-Line, and probably now is a real estate office.
Execution time: 0.791 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:16 PM
