Username Post: Chrome trim        (Topic#375766)
JP50
Reg: 10-09-21
09-27-24 11:04 AM - Post#2874258
Hi, does anyone know of a source to find the chrome trim that sits below the window line? I’m not sure what it is called. I’m after the trim for a 1950 2dr coupe. Thanks
eplantage
Loc: Southern MN
Reg: 03-15-04
09-27-24 12:50 PM - Post#2874260
    In response to JP50
It's referred to as "Belt Line Trim". Easily found on Ebay.
Age: 70 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
US Navy Seabees EO2 77-83, 86-88
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
09-30-24 09:41 AM - Post#2874316
    In response to JP50
To be technically correct, this is not chrome, but polished stainless steel. eBay as eplantage pointed out or, from a wrecking yard. To my knowledge, it is not being reproduced.
1951 Fleetline Preservation
'51 Fleetline DeLuxe, POWERglide 2-DR (Fathom Green)
'53 6500 Dump Bed (Faded Red)
'50 Styleline DeLuxe 4-DR (Mist Green)
JP50
Reg: 10-09-21
09-30-24 11:23 PM - Post#2874328
    In response to RAM_51
Thanks for the suggestions and the help with what it’s called, unfortunately I’m not in the USA so eBay may be my only option. So far I’ve only been able to find 4dr trim.
RAM_51
RAM_51
Reg: 12-28-02
10-01-24 09:32 AM - Post#2874338
    In response to JP50
Just be aware also that the trim from a Belair, Convertible or Sedan Delivery is different, even though those are 2-Door models. Only Coupe, 2-Door Sedan or 2-Door Fleetline will work.
The Master Parts Manual lists it this way:
12.112 MOULDING, Front Door Belt
1949-1952 Jobs 1007-11-27-1207-11-27-27B ....(1-1/8 wide x 41-7/8 long) Left = 4561290, Right = 4561291.
The Convertible and Belair are the same length, but the shape at the rear is different and the Sedan Delivery is 36-1/16 in length (same length as the front door on the 4-Door, but again, the shape of the end is different).
1007 = Fleetline DeLuxe 2-Door
1011 = Styleine DeLuxe 2_door Sedan
1027 = Styleine DeLuxe Sport Coupe
1207 = Fleetline Special 2-Door
1211 = Syleline -Special 2-Door Sedan
1227 = Styleine Special Sport Coupe
1227B = Styleline Special Business Coupe
eplantage
Loc: Southern MN
Reg: 03-15-04
10-02-24 09:43 AM - Post#2874374
I believe that the trim below the windshield is the same for all models. This is installed under the wiper transmissions.
RAM_51
RAM_51
Reg: 12-28-02
10-02-24 11:37 AM - Post#2874378
    In response to eplantage
That is correct. Again the Master Parts Catalog entry:
10.093 MOULDING ASSEMBLY, Windshield Reveal
1949-52 PASS......lower, Left = 4562379, Right = 4563588
Simply "PASS" without regard to model. Of course the moulding from the door to below the rear window is also peculiar to the coupe models.
JP50
Reg: 10-09-21
10-04-24 08:30 PM - Post#2874424
Are the rear window belt line trims the same across the vehicles 4dr and 2dr?
whiskey1954
whiskey1954
Loc: central north carolina
Reg: 12-07-08
10-05-24 03:57 AM - Post#2874425
    In response to JP50
NO
Execution time: 0.426 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:46 PM
