Mjgarcia88
Loc: Victorville, California
Reg: 02-02-23
09-26-24 09:04 PM - Post#2874237
I have a GM 250 inline 6 (year 1973). I just started the engine and the ignition coil got extremely hot after starting the engine a few times. I didn't use the condenser with the coil because im unsure if its required for a 12 volt system. I don't think it's normal for the coil to get really hot? This is my first time working a inline 6.
Anyone have any ideas as to why the coil would get hot?
Thank you
GreatNorthWoods
Reg: 03-31-02
09-27-24 02:10 AM - Post#2874243
In response to Mjgarcia88
It is probably okay. Most coils are hot to the touch. Coils run hotter than most people realize and in standard ignitions its not uncommon for the coil to see close to 200 degrees.
Vern
1930 DeSoto CK Business Coupe- 350 Chevy Crate V8, 4-wheel disc brakes, TH400, S-10 Rear, Heidt's IFS, A/C |
bobt
Loc: colonial heights va
Reg: 06-28-14
09-27-24 03:09 AM - Post#2874244
The condenser on the coil was used to reduce radio noise. I'm guessing you're not talking about the condenser for the points.
09-27-24 05:36 AM - Post#2874245
Is the coil an internally resisted coil, or is it wired through an external resistor? Constant 12v at the coil if not internally resisted could cause to run hotter.
Mjgarcia88
Reg: 02-02-23
09-27-24 08:47 AM - Post#2874253
Oh ok thank you. I was worried
Mjgarcia88
Reg: 02-02-23
09-27-24 08:48 AM - Post#2874254
I don't recall if its an internally resisted coil. I will have to look into it. Thank you for the help. I might just go buy a new 12v coil today and see what happens
Mjgarcia88
Reg: 02-02-23
09-27-24 08:49 AM - Post#2874255
In response to bobt
It shouldn't hurt to just add the condenser with the points coil?
52_Belair
Loc: Canby, Oregon
Reg: 03-25-03
09-27-24 10:25 AM - Post#2874256
You could also use longer mounting bolts and use spacers to move the coil away from the head, maybe even add a heat shield.
As a side question for anyone who might know. I see that engine has side engine mounts. Would that engine fit in a 1952 with side mounts? Does that engine have hydraulic lifters?
Kyle G.
Loc: Delanco, New Jersey
Reg: 11-29-15
09-27-24 08:21 PM - Post#2874264
You can check the coil to make sure it's appropriate for the electrical system voltage of your car. 6V coils measure approximately 1.5 ohms across the + and - terminals. 12v coils measure approximately 3 ohms.
1950 Chevy Styleline Deluxe w/ '60 235 engine and '58 torque tube 3-speed overdrive with 3:55 gears in the back
1946 Willys CJ-2A |
bobt
Reg: 06-28-14
09-28-24 02:26 AM - Post#2874265
If the old coil is internally resisted it will be printed on the side of the coil. I don't think you should buy a new coil.
