Username Post: Transmission rebuild options?        (Topic#375668)
RonWT
Loc: California
Reg: 09-08-24
09-08-24 07:07 PM - Post#2873617
Hi, first time poster here. We have a 1969 C10 2wd with a 350 engine and a turbo 400 transmission. The pickup is 100% stock, and has 3.73 gears. I am thinking of putting a 2000 stall speed converter, would anyone with experience offer up any opinions? I am having the transmission completely rebuilt.
Thank you,
RonWT
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
09-09-24 02:05 AM - Post#2873624
    In response to RonWT
What do you hope to accomplish with the higher stall converter? I doubt that a 2000 RPM stall converter will make much difference. The stock stall speed for your TH400 is probably around 1600-1800 RPMs, so another couple of hundred RPMS won't make much difference except make the engine use more gas.
Vern
1930 DeSoto CK Business Coupe- 350 Chevy Crate V8, 4-wheel disc brakes, TH400, S-10 Rear, Heidt's IFS, A/C
09-09-24 08:26 AM - Post#2873645
depending on use you would probly want a heavy duty or towing rv type rebuild.
RonWT
Loc: California
Reg: 09-08-24
09-09-24 04:11 PM - Post#2873662
    In response to bobb
Thank you
Execution time: 0.276 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:33 PM
