Username Post: 1948 Fleetmaster Ignition Switch        (Topic#375580)
Brad51
Loc: CT
Reg: 06-18-24
08-25-24 05:48 PM - Post#2873076
I recently picked up this car but the previous owner had removed the ignition switch to have a key made. My problem is there are 4 wires that need to be reattached but only 3 terminals. The wiring diagrams I have found on line are no help. Can someone set me straight on how to hook it up?
09-01-24 10:17 AM - Post#2873326
    In response to Brad51
welcome to ct. its gonna be a trial and error thing. get a test light or better a multimeter and start testing.
52_Belair
Loc: Canby, Oregon
Reg: 03-25-03
09-02-24 10:40 AM - Post#2873373
Is it the original switch or is this a mod?
I'm not familiar with the older switch, if it's like my '52 the switch is either On or Off, no accessory position, so one terminal for power the others for ignition, gauges and anything else that goes Off with the key. After finding the power lead you might try to put power on each of the other wires, after checking for a ground issue first, and see what each wire powers up.
And yes, the wiring diagram in my shop manual kinda looks like spaghetti LOL.
Member #189 Moderator and "22nd Year" Platinum Supporting Member
09-03-24 10:24 AM - Post#2873419
    In response to 52_Belair
Here is the explanation of the key switch.
http://chevy.oldcarmanualproject.com/chevyowner/48...
29-41, 42-48, 49-54 Moderator
Execution time: 0.38 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:51 PM
