Username Post: Heater core bypass valve        (Topic#375533)
08-18-24 09:32 AM - Post#2872825
Walking around at a local car show, I found a '56 Chevy with heater hose bypass valves. I like them. I didn't find the owner to ask the brand name. Has anyone seen them? When the A/C is off, having a bypass will help keep the cab cooler. The continuous fan low speed heats up the cab way too much.
Attachment: valve.jpg (56.76 KB) 77 View(s)
'08 GMC Acadia 3.6L SLE
Edited by gchemist on 08-18-24 09:32 AM. Reason for edit: No reason given.
08-18-24 10:52 AM - Post#2872827
you only need one. the input to heater core. a simple ball valve will work good.
08-18-24 12:12 PM - Post#2872838
    In response to bobb
Hey bobb, I hadn't thought about installing just one. I could try that first. If enough heat is reduced, no need for complete flow cut off.
1983G20Van
Loc: Hurst, Texas, USA
Reg: 11-13-02
08-24-24 10:13 AM - Post#2873012
I haved used a simple ball valve in the heater core supply hose for years on numerous vehicles. My 83 G20, 87 G20, 97 Express and 2006 Ram to name a few.
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
08-27-24 03:25 PM - Post#2873128
    In response to 1983G20Van
I heard about this a few years ago. After reading this, I'm thinking about doing it. Is there an actual noticeably difference using a cutoff valve?
1974 Cheyenne 10 LWB STOCK 350 W/HEI /TH350 /AC/ 4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
08-28-24 01:49 PM - Post#2873178
    In response to Liberty Valance
A four port valve is on order. I'll post a picture once I have it installed.
Yes, heat temps will be different. Even with the heater/A/C off, the blow motor still spins. With hot water in the heater, the heat is transferred into the cab. It's very noticeable on mine. The A/C system will work better too.
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
08-28-24 02:40 PM - Post#2873180
I have a 4 speed fan with AC. I have removed the low speed wire from resistor connector so now I have a 3 speed fan with an off position. I did not like the fan running all the time, especially in winter cause when starting, the default setting was air was blowing from AC vents and it was cold.
Mopar by Birth
Chevy by Choice
09-02-24 01:05 PM - Post#2873380
Here's the heater core bypass valve. I plan to drain enough coolant to install it. Quick switch over when the heater is needed. The A/C will work better too.
Attachment: valve.jpg (61.05 KB) 25 View(s)
64ss409
Reg: 12-04-02
09-03-24 06:52 AM - Post#2873407
I put a single shutoff valve, like in the first photo, in my grain hauling trucks. I shut the valve during harvest so no water flows.
Ron
1962 SS convertible, 327/250 4 spd
1956 IH pickup, 327
09-06-24 04:44 PM - Post#2873548
    In response to 64ss409
The bypass valve is installed. I didn't get a chance to turn it on. I'll bleed out the air next week. I pumped out about a gallon of coolant. It was enough not spill any at the heater hoses. It's in the bypass position. A simple turn will allow hot water into the core. It will be nice not to have excess heat in the cab.
Attachment: valve.jpg (139.6 KB) 10 View(s)
Execution time: 0.724 seconds.   Total Queries: 20   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:24 PM
