grumpyvette
Performance Subject Matter Expert --
Loc: farmersville texas USA
Reg: 03-16-01
07-17-24 12:25 AM - Post#2871854
In response to mag
could you be a bit more specific in the type of noise and under what conditions, now that might seem like a silly question, but doing something like removing the muffles while obviously a dumb move is a way to make more noise, a change in the type of muffler , while a bit expensive can also get you a significant increase in noise, but in a much more controlled way, why not talk with a local exhaust shop?
IF YOU CAN , YOU NEED BETTER TIRES AND YOUR SUSPENSION NEEDS MORE WORK!! |
Edited by grumpyvette on 07-17-24 12:26 AM. Reason for edit: No reason given.
