Username Post: from a slight "charge' to "discharge" ? what's with this/        (Topic#375309)
matt49
Reg: 05-26-05
07-09-24 04:25 PM - Post#2871620
My stock '49 Chev 216 always showed a slight + on the amp gauge. Now it's a slight discharge, even at fast idle. Then when the head lights are turned on it's a MAJOR discharge. Checked the non-adjustable voltage regulator for contact point gap/cleanliness. Time to rebuild the generator? The generator has been untouched since '97. Battery is a couple years old, stored in winter, and cranks fine....but this draw is taking its toll. Any thoughts?
Regards and thanks from Matt
07-09-24 04:56 PM - Post#2871622
    In response to matt49
To check generator output, momentarily ground the field terminal on the generator, engine at 1,500 rpms your volt meter on the battery terminals would be around 7.8-8.0 volts,this eliminates the regulator also. Post back results.
Doug52sedandelivery
Doug52sedandelivery
Loc: Eddyville KY
Reg: 01-22-20
07-11-24 03:24 AM - Post#2871660
You might need to flash the generator as it may have lost its residual magnetism. I had to do this on my 35 ford. It got it charging again
Here is a link on how to do it. It is for a 12 volt system. Works the same just use your 6 volt battery
https://101generator.com/how-to-flash-a-genera tor/
Doug
bobt
Loc: colonial heights va
Reg: 06-28-14
07-11-24 06:25 AM - Post#2871663
    In response to Doug52sedandelivery
polarizing the voltage regulator is the same as flashing and all you need is a paperclip or a short piece of wire
matt49
Reg: 05-26-05
07-11-24 06:39 PM - Post#2871675
I took Shepherd's suggestion. At 1500 rpm I disconnected the FLD connector from the voltage regulator and grounded it. Battery voltage reading was 6.02 volts, which tells me Mr. Generator isn't doing his job.
Haven't tried "flashing" yet.
Battery has been slowly discharging the past couple weeks. Turning on the headlights pegs the amp gage on the discharge side. Regulator points are clean and gapped, no corrosion or broken windings. Connections are clean, tight and not broken. Belt is not loose. Generator has not been serviced since at least 1997 when I "rescued" my Fleetline.
Any additional thoughts before generator goes to surgery?
Thanks in advance.
Matt
Execution time: 0.914 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:00 PM
