Username Post: 72 el camino ss454 torque converter        (Topic#375308)
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
07-09-24 08:28 AM - Post#2871606
my 72 elcamino ss454 engine has a mild cam, the larger valves and 10.0 compression. it is otherwise stock. it has the turbo 400 transmisson with 3.55 rear gear
. i had to replace the torque converter when i rebuild the engine due to the guide where the torque converter goes into the crank being broken. i replaced it with a stock converter since i thought that is what i had. anyway, this converter broke within a couple of hundred miles. i was told it had a stall of 1450rpm, which i think was about right. i think my cam would like a stall of around 2000rpm since i currently have to idle the engine at 1100 to 1200 rpm to keep it running in gear with the ac on.
i would like you'alls recommendations as to brand, stall etc.
any thought would be appreciated.
Attachment: 100_2527.JPG (567.96 KB) 5 View(s)
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
15 chevy equinox
07-09-24 06:26 PM - Post#2871627
    In response to 62chevy427
Actual cam specs would help any advice here.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
07-10-24 07:36 PM - Post#2871655
the specs for the cam are 515 lift for both intake and exhaust, 276/286 duration, lsa 112* rpm range 1200 to 5800. thanks
95 impala (new)
15 chevy equinox
07-11-24 05:39 AM - Post#2871662
I would suggest 2,000 stall converter would do the job.
07-11-24 08:50 AM - Post#2871665
for a bit more yank from a dead stop i would get a bit more than 2000. depends on your driving needs.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
07-12-24 08:37 AM - Post#2871684
    In response to bobb
i'm thinking between 2000 and 2400 stall. don't want too much since i like to cruise and it has a 3.55 rear gear and no overdrive.
anyone have suggestions as to what brand to get?
95 impala (new)
15 chevy equinox
07-14-24 10:12 AM - Post#2871765
i had a 2000 in a 3500 van 383. it felt stock.
Execution time: 0.86 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:01 PM
