Username Post: Brake lines        (Topic#375300)
07-07-24 09:00 AM - Post#2871545
Has anyone replaced all their brake lines? Especially the rear line? I helped do some work on a '82 K20. The owner couldn't get brake fluid to the rear. We opened line fittings one at a time working forward. No fluid at all at the rear split, flex hose, or first mid body connection. The line was rusted up inside. We broke it off while trying to separate the line at the mid frame union. The line was replaced at the union to the rear split. A new flex line was installed. Still no fluid. We opened the line fitting on a new proportion valve. Fluid did come out. The rest of the line will be replaced. The inside is rusted from moister. It was left without fluid for too long.
'08 GMC Acadia 3.6L SLE
07-07-24 11:14 AM - Post#2871555
uh, if the lines are that bad, the rest of the system may be ready to fail also.
07-07-24 11:31 AM - Post#2871557
The shuttle valve in the proportioning valve can close off fluid to the rear, if pressure is lost in the rear. Plenty of info on the net how to bleed the rear brakes if this happens.
Edited by Shepherd on 07-07-24 11:32 AM. Reason for edit: No reason given.
07-07-24 01:53 PM - Post#2871561
The front lines and flex hoses have been replaced. Calipers and brakes pads are new. The proportion valve was changed to see if fluid would flow back. Fluid comes out at the valve. We couldn't blow air through the remaining stock line. A new line will be bent and installed. The truck comes from a coastline. I would replace all the brake lines. Rear wheel cylinders and brakes are new.
Here's the interesting part. The K20 was originally a diesel. It's now a 350 SB truck. The hydro boost brake set up is in place and connected.
Execution time: 0.303 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:22 PM
