Username Post: Dual Batteries        (Topic#375296)
stpat
Reg: 07-06-24
07-06-24 02:45 PM - Post#2871523
Did the 1998 Suburban 2500/w/454 have dual batteries in the stock configuration?
07-07-24 10:43 AM - Post#2871552
    In response to stpat
welcome to ct. my guess is that it was an option.
Senior Moderator
07-07-24 07:34 PM - Post#2871575
Like bobb alluded to, it's likely a factory option. It would not automatically come with dual batteries.
You may find that option on the sticker in your glovebox, the SPID (service parts identification) label. The 3 digit codes on that label correspond to all the different options the vehicle is built with. There are some sites that will decode it for free - you can try the NHTSA website and enter your VIN. For some vehicles it will break down the list of options for you. Or some that cost a few bucks like Compnine. Also, your local Chevy/GM dealer should be able to give you a build report printout based on the VIN if you ask them nicely.
06 Silverado ISS / 06 Silverado SS / 06 300C SRT8 / 93 C3500 dually
Keith Seymore
Keith Seymore
Loc: Southeast Michigan
Reg: 09-17-08
07-08-24 11:46 AM - Post#2871591
    In response to someotherguy
I did not see any mention of it in the generic info packet in the GM Heritage Center archive:
https://www.gm.com/content/dam/company/n o_search/h...
During the squarebody era ('73-'91), RPO TP2 Dual Battery was available only on pickup, not SUV. There was an SEO (specialty equipment option) for fleet use that would add a dual battery to a Suburban. I do not remember the code off hand.
I cannot speak with authority regarding the GMT400 versions (1992 and newer).
K
Chevelle Intro: https://www.chevytalk.org/fusionbb/showtopic.php?t...
My Pontiacs: http://forums.maxperformanceinc.com/forums/showthr...
Pickup: http://67-72chevytrucks.com/vboard/showthread.php?...
Edited by Keith Seymore on 07-08-24 11:47 AM. Reason for edit: No reason given.
Keith Seymore
Keith Seymore
Reg: 09-17-08
07-08-24 11:50 AM - Post#2871592
Also - keep in mind there were two different dual battery configurations.
TP2 provided a primary battery for vehicle use (like cranking) and the second battery for camper/trailer use. The second battery was isolated from primary so that you wouldn't accidentally run it down and not be able to start your vehicle.
For diesel - the two batteries were wired equally (in parallel) so that both were used for cranking.
If yours is a factory set up then it would be the first type.
K
Edited by Keith Seymore on 07-09-24 03:56 AM. Reason for edit: No reason given.
Execution time: 0.319 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:29 PM
