Eth727
![Eth727](https://www.chevytalk.org/fusionbb/images/avatars/2.jpg)
Loc: San Diego
Reg: 04-17-19
06-10-24 11:28 AM - Post#2870738
Eth727
Loc: San Diego
Reg: 04-17-19
06-10-24 11:41 AM - Post#2870740
In response to Eth727
Endless64
![Endless64](https://www.chevytalk.org/fusionbb/fbbavatars/av-315206-1709608192.jpg)
Loc: Menlo Park, California
Reg: 11-10-21
06-10-24 12:03 PM - Post#2870741
A quick search says 56-63 3 speed manual, possibly out of a Corvette.
Have never lived in the past, but arrived there recently |
Eth727
Loc: San Diego
Reg: 04-17-19
06-10-24 02:14 PM - Post#2870745
In response to Endless64
Saginaw,Muncie?
Endless64
Reg: 11-10-21
06-10-24 03:40 PM - Post#2870748
The internet says 4 bolt side cover = Muncie.
327
Loc: Ontario , Canada
Reg: 02-09-21
06-10-24 04:10 PM - Post#2870750
Member #51
06-10-24 05:42 PM - Post#2870754
In response to 327
I've tried to get this across to people, but there are some people out there who REALLY refuse to acknowledge or accept it.
That is a SAGINAW design 3sp, built at the Muncie plant. It is NOT, repeat, NOT a Muncie design!!!!!!!!!!!! It is a Saginaw design, AGAIN, built at a Muncie plant. Oh well, some will REFUSE to accept this. OK.
That particular 3sp is a 58-65 version-----------FOR PASS CARS----------NOT Corvettes.
It has the short tail housing with the mount provision at the rear of the tail housing------------------ --THIS IS ONLY A PASS CAR FEATURE!!!
Even though the design was 58-65, there was a MAJOR INTERNAL change to all gears as well as the tail shaft which went from 16splines to 27 splines for 63-65 versions.
The Corvette 3sp had the long tail housing, with a providion for a mount.
AND, AND, AND------------THE CORVETTE TAIL HOUSING HAD BOSSES WITH THREADED HOLES FOR MOUNTING THE SHIFTER.
Eth727
Loc: San Diego
Reg: 04-17-19
06-10-24 09:50 PM - Post#2870762
Is this tranny correct for a ‘63 , 3 speed? And if it’s not what is the one that is?
Member #51
06-11-24 10:42 AM - Post#2870773
Does it have the coarse spline (16splines) or the fine spline (27splines) tail shaft?
The 58-62 had the 16spline tail shaft. The 63-65 had the 27spline tail shaft.
Eth727
Loc: San Diego
Reg: 04-17-19
06-11-24 05:03 PM - Post#2870784
Dave_Neiling
![Dave_Neiling](https://www.chevytalk.org/fusionbb/images/avatars/sm.jpg)
Loc: Custar, Ohio United State...
Reg: 12-10-01
06-11-24 05:45 PM - Post#2870787
So thats an early one thanks DZ you learn something new everyday.
Member #51
06-12-24 04:21 PM - Post#2870813
In response to Dave_Neiling
That is the 55-62 style tail shaft splines.
These are 4spds. The coarse, 16spline is a 62-earlier, the fine, 27spline is a 63-later. The shafts are the same diameter, just different splines.
