gregice1958
Reg: 05-20-24
05-21-24 04:30 AM - Post#2870077
Hi everyone. I installed a reman generator on my 41 Chevy MD Coupe 216 CID. I polarized at the regulator and then again at the generator. My OE ammeter reads very slight discharge, where in the past it has always been very slight on the charge side. I measure my battery and I'm 6+ volts, but when I start it, the readings fluctuate everywhere between 7.6 and 1.76 volts, never steady while running even at 1500 rpm. Is this normal? Can I test the generator and alternator while the engine ids running? Sorry for the book. I'd appreciate any and all suggestions. Thanks, Greg
Edited by Tony on 05-21-24 04:39 AM. Reason for edit: Moved to correct forum
Member #189 Moderator and "22nd Year" Platinum Supporting Member
![Keith_Knox](https://www.chevytalk.org/fusionbb/fbbavatars/av-189-1614753536.jpg)
05-21-24 03:10 PM - Post#2870088
In response to gregice1958
Welcome to ChevyTalk.
29-41, 42-48, 49-54 Moderator
2019 Ford Ranger Lariat Super Crewcab |
05-21-24 04:21 PM - Post#2870089
Ground the field wire on the gen, engine at 1500 rpms, voltage should be at least 7.8v. Don't ground the field wire for more than 15-20 seconds while doing this.
