Username Post: return line for efi        (Topic#375059)
498 chevy 73
498 chevy
Loc: hayward ca.
Reg: 09-28-07
05-20-24 09:29 AM - Post#2870066
big ? can i use the return line that was for charcoal filter canister on 74 c 10 for efi return gas line ? or do I have put in a return line for this. Im not using the charcoal canister on mine truck thanks
toro455
toro455
Loc: Western NY
Reg: 06-15-02
05-23-24 03:06 PM - Post#2870139
    In response to 498 chevy
What diameter is the line you want to use? If it's 1/4" that's smaller than recommended.
498 chevy 73
498 chevy
Loc: hayward ca.
Reg: 09-28-07
05-25-24 09:09 AM - Post#2870187
    In response to toro455
its 3/8 dia. and it go's directly into the top of tank where the out let is
Edited by 498 chevy on 05-25-24 09:11 AM. Reason for edit: No reason given.
05-25-24 10:16 AM - Post#2870191
that would work well if it has a tube inside the tank that drops down so the fuel is not splashing around in there getting all airated.
Edited by bobb on 05-25-24 10:18 AM. Reason for edit: No reason given.
toro455
toro455
Loc: Western NY
Reg: 06-15-02
06-08-24 10:25 PM - Post#2870675
The 3/8" line is great. They do however recommend that the return, for EFI, exit very close to the bottom of the tank. I think Holley has a guideline. I found something once and have just followed it.
Scott
Execution time: 2.084 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:51 PM
