Username Post: 65 four door and 2 door door latches? Same?        (Topic#374776)
bestpaint
Loc: Hartford South Dakota
Reg: 07-23-09
04-01-24 01:32 PM - Post#2868509
I have a customer that has a 4 door 65 that the drivers door latch is not latching fully. Seems to function when clipping it shut on its own and will release fine. When shut the door suddenly it just does not fully latch through the second faze of the process. I played with the striker as at 1st thought maybe the striker had come loose enough to move in. Did not matter if I moved it in or out the same results happened on shutting the door. I have seen the latches being listed naturally on 2 doors. Are they by chance the same as a 4 door latch? Tried ebay and found a passenger listed for a 4 door. It does look similar enough to the pictures places like NPD list 2 door latches. I did reach out to my guy I deal with at NPD and he said he shows they only fit 2 doors. If they are different anyone know anyone that might be selling a 4 door latch?
corey
bestpaint
Reg: 07-23-09
04-03-24 08:50 AM - Post#2868547
    In response to bestpaint
Anyone know for sure if 2 doors are the same or a source for a 4 door left front door latch?
corey
bestpaint
Reg: 07-23-09
04-08-24 09:28 AM - Post#2868701
Anyone? Or know where we can source out a good used one?
corey
bestpaint
Reg: 07-23-09
04-30-24 09:29 AM - Post#2869331
does anyone happen to know if they are the same or different? Anyone know of a supplier of possible a good used one? Customer would like to find one.
thank you
corey
bestpaint
Reg: 07-23-09
05-10-24 11:39 AM - Post#2869719
510 views and noone has an idea or possible lead to one. Any other ideas on finding out the information?
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
06-13-24 04:09 PM - Post#2870838
My parts catalogue lists only 1 P# ea., LH & RH. Doesn't specify 2 or 4 dr models and no other P#s so my answer is front doors are same, 2 or 4 dr.
Note factory terminology the latch is called a "Lock"....key cylinder is referred to as "cylinder, door lock"
Attachment: door_locks.jpg (87.26 KB) 26 View(s)
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
Execution time: 1.719 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:41 PM
