64K10
Loc: Cali
Reg: 06-25-04
03-07-24 02:24 PM - Post#2867651
FYI... found two fittings locally.
Motor is a '56 - 235
Looking for two fittings, one goes on the oil pump output side, the other on the block.
The fitting/adapter is 1/4" pipe to 7/16" compression and is just over an inch long.
The fitting/adapter is M/M and the 1/4" pipe side screws into the oil pump and the other one into the block. The steel 7/16" crossover tube ends use a ferrule and compression nut on each end to attach to the fittings.
Also posted this the Truck section. Motor is going in a '50 Panel. Any leads on finding one or both would be much appreciated.
Thanks,
Edited by 64K10 on 03-23-24 01:14 PM. Reason for edit: No reason given.
