Username Post: 2015 LTZ fleet body issues        (Topic#374593)
C10KLee
C10KLee
Loc: NC
Reg: 10-14-07
02-29-24 03:21 AM - Post#2867375
I'm getting a vibration from about 70-80ish. Pretty sure that one's the tires,but would worn struts cause this, too?
Also, constant warning messages in dash; check stabilitrak, traction control, brakes. Money is tight. Gotta look at it this weekend. Tha is for any info.
02-29-24 12:59 PM - Post#2867391
    In response to C10KLee
Usually not a strut issue, car vibration, steering wheel vibration? Got the codes read?
C10KLee
C10KLee
Loc: NC
Reg: 10-14-07
02-29-24 01:49 PM - Post#2867393
Didnt think it should be struts, either. Haven't read codes, but I know its overdue for brakes and the tires are worn. Gonna pull the wheels this weekend and look at it. Thinking it might be a wheel hub assembly, based on the dash messages and comparing notes with a friend who has the same car.
02-29-24 06:55 PM - Post#2867412
Sounds like you are on the right track.
C10KLee
C10KLee
Loc: NC
Reg: 10-14-07
04-02-24 04:02 AM - Post#2868521
Looking at tires for primary cause of vibration. Found some defects around middle of tread on LF. Now, I have a power issue. As in none. Battery was low and put a charger on overnight. This AM, it's 100%, but no juice anywhere.
04-03-24 03:07 PM - Post#2868550
Dirty cable connections and grounds?
C10KLee
C10KLee
Loc: NC
Reg: 10-14-07
04-05-24 12:50 PM - Post#2868605
Another dead battery. Just bought it last April. Got a replacement for free. One down, ten to go.
C10KLee
C10KLee
Loc: NC
Reg: 10-14-07
04-06-24 04:37 AM - Post#2868624
Possibility is medium high for hub replacements in the not too distant future. Wheel sensor(s) is acting up. Any brand recommendation or advice? Same with struts.
C10KLee
C10KLee
Loc: NC
Reg: 10-14-07
04-26-24 11:20 AM - Post#2869200
Got the vibration sorted. 8t was the tires. Also got rid of the check engine light with a new purge valve. Next up is the wheel hubs. Hope to look at them this weekend. Be nice to find an easy fix like a loose, frayed wire.
Execution time: 0.041 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:43 AM
