Da boss
Reg: 02-03-24
02-11-24 03:10 PM - Post#2866808
In my 1962 impala the neutral saftey switch is bypasses with a paper clip to jump the 2 purple wires . The car starts fine but I want to use the neutral saftey switch just for safety so it won't start in the drive position . I plugged the 2 wires to the switch by doing that the car won't start [image]https://ibb.co/Cm0hP2k
https://ibb.co/qNrMndb[/image] is my switch bad .
61ragtop
Loc: Langley B.C. Canada
Reg: 07-30-03
02-11-24 04:20 PM - Post#2866812
In response to Da boss
could be out of adjustment. reconnect the wires, loosen the screws to the switch. With it in park move the switch unti it turns over.....
junky
Loc: Northeast CT
Reg: 06-27-10
02-11-24 07:10 PM - Post#2866814
In response to 61ragtop
I agree that it is most likely out of adjustment, however, I would try moving the gear shift lever through the gears with the switch plugged in. Make sure to keep your foot on the service brake, and have the parking brake tightly engated. Might not be a bad idea to block the wheels in both directions. Be ready to shut it off if it starts and note exactly where the gear selector is when the starter engages. That will tell you if the switch is defective or just out of adjustment. The other two terminals are for the back up lights.
61ragtop
Reg: 07-30-03
02-13-24 12:33 PM - Post#2866856
In response to junky
Could also just remove switch leave in park and manually move the switch till it starts if it does. or use a multimeter to test it....
327
Loc: Ontario , Canada
Reg: 02-09-21
02-13-24 06:25 PM - Post#2866870
Da boss
Reg: 02-03-24
02-18-24 01:53 PM - Post#2867007
In response to 327
I purchased a new saftey switch the old one fell apart . I adjusted the new one and i got power going . My reverse lights dont work. I assumed these new switch would fix this problem . I cleaned the light bulb contacts and the housing since they ground thorugh there. Any ideas were i should be looking ? Thanks
Da boss
Reg: 02-03-24
02-18-24 09:30 PM - Post#2867023
I did some more work on my problem . Im not getting any power to one of the cables. Is there a fuse in one of the cables
Da boss
Reg: 02-03-24
02-25-24 08:17 PM - Post#2867263
I got all lights working had to do some rewiring. Now on to the interior lights hoping its just some burnt light bulbs.
