61ragtop
Loc: Langley B.C. Canada
Reg: 07-30-03
02-10-24 09:17 PM - Post#2866793
Hey guys I am just getting all my suspension parts back from the painter and am looking to install all the bushings. Any tips or advice on how to do this at home? I have all the bushings etc for the front and real arms.
junky
Loc: Northeast CT
Reg: 06-27-10
02-11-24 07:13 PM - Post#2866815
In response to 61ragtop
They need to be pressed into the arms, and the ears of the arms need to be supported when they are being pushed in. Check your factory service manual to see the instructions. I know how to do it, however, I didn't have all the correct tools and it was faster and easier to have the local machine shop do the job with both their experience and equipment. If you mess up the ears, you will be looking for new control arms.
pvs409
![pvs409](https://www.chevytalk.org/fusionbb/fbbavatars/av-26453-1368069215.jpg)
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
02-11-24 07:16 PM - Post#2866816
The bushing mounting surfaces should not be painted.
If they painted them you need to remove the paint were the bushings mount.
All my bushings were installed before power coating. I had them installed using a press on multiple restoarations
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
https://paulstensland.com
61ragtop
Reg: 07-30-03
02-13-24 12:31 PM - Post#2866855
In response to pvs409
Thanks guys for the advice! I just ordered the right tool topress them in...
junky
Loc: Northeast CT
Reg: 06-27-10
02-13-24 07:26 PM - Post#2866873
Did you order the bar to keep the ears in alignment? You need that to keep from pushing them together.
61ragtop
Reg: 07-30-03
02-14-24 11:50 AM - Post#2866898
In response to junky
I bought the upper control arm bushing service kit
https://www.powerbuilt.com/products/upper-contro l-...
it does one end at a time so the ears won't bend asa posed to a press. for the lowers I will need to make a spacer for them but thats easy....
