Username Post: 2017 2500HD - Mirrors Freeze-Up        (Topic#374472)
HandyAndy
Loc: Iowa City, IA
Reg: 09-05-19
02-09-24 07:34 AM - Post#2866737
Unfortunately, my 2500HD sits outside. Occasionally after a wet snow, rain, and freezing temps, the electric folding mirrors freeze in the folded in position. Once it warms up outside the mirrors operate as they should. I'd leave them extended, but they're in the way when parked in the driveway.
Any solutions out there? Thanks!
HandyAndy
steve65
steve65
Loc: Langley, BC
Reg: 09-25-13
02-09-24 06:44 PM - Post#2866755
    In response to HandyAndy
Maybe a blow dryer or heat gun until they open? Then close them and drive out, then open them again?
Just a thought.
Steve
Steve Duncan
66 Impala 2dr Coupe
Sold, gone to a better home.
blang88
Reg: 01-29-24
02-11-24 12:08 PM - Post#2866804
Is it hard to just manually fold them by hand?
Just bought a 2024 Chevy Silverado 1500 LT and negotiated $9k off MSRP. I brag about it every chance I get!
HandyAndy
Loc: Iowa City, IA
Reg: 09-05-19
02-13-24 07:23 AM - Post#2866847
    In response to blang88
Thanks, I have thought about a blow dryer or a heat gun. I'm not familiar with the internal workings of the mirrors. Likely some gear set-up. I don't want to force something and break it.
It's clear that moisture is the problem during freezing temps. Where could I find a parts diagram for the mirrors. Maybe a silicone based grease to keep moisture out of the gears?
HandyAndy
elcamino
elcamino
Reg: 03-30-00
02-21-24 05:19 PM - Post#2867111
Can't you spray some water displacing liquid where the mirrors pivot? Thats what I would do and this is what I would use, It contains no silicone, and is compatible with plastic, leather, fabric,
fishing line and paint.--------->MP Metal Protector
2021 GMC 4WD Sierra Denali Ultimate 6.2L/10-sp
2022 Polaris RZR XP 1000 Ride Command
2017 John Deere X738
HandyAndy
Loc: Iowa City, IA
Reg: 09-05-19
02-21-24 07:56 PM - Post#2867115
    In response to elcamino
Well, that seems like a good idea. I'll have to look into that product. The other thing I saw on YouTube, was a guy using WD-40 with silicone; however, his mirrors were dragging and not freezing due to moisture. He used a quick spray in the lower pivot on the mirrors and it made a noticeable improvement in the operation of them.
Does anyone know what the gears are made of in these mirrors(plastic, nylon, metal)? I'd feel better knowing that before I spray anything in the pivots.
Thanks,
HandyAndy
elcamino
elcamino
Reg: 03-30-00
02-23-24 03:48 PM - Post#2867172
Everything is made of plastic. I seen a busted up one.
HandyAndy
Loc: Iowa City, IA
Reg: 09-05-19
02-23-24 06:14 PM - Post#2867177
Thanks Mike,
That's the info I was looking for, plastic gears. I'll see if I can locate the Amsoil Metal Protector locally. Maybe treating the mirrors in the Fall would keep them operable during the Winter months.
Thanks again,
HandyAndy
elcamino
elcamino
Reg: 03-30-00
02-26-24 10:46 AM - Post#2867280
Even being preemptive, they still may freeze up as cold weather is unpredictable on moving parts.
HandyAndy
Loc: Iowa City, IA
Reg: 09-05-19
02-26-24 12:24 PM - Post#2867285
I understand and I think doing something like you've recommended with a water displacement lubrication just makes sense.
Another thought I had was to try and put a rubber sleeve or boot over the pivoting joint on the mirrors. I'm not sure how they would fit over the mirrors, but something like that may help keep moisture out of the pivot too. Any thoughts?
HandyAndy
Execution time: 0.131 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:40 PM
