i have stock 98-02 camaro manifolds in my 57 and they clear the stock manual steering box with the mounts I used
there is about 3/8" clearance with the nearest bolt for the heat shield removed. the exit clears the pitman arm and everything, and the passenger side is plenty clear of everything
