Da boss
Reg: 02-03-24
02-04-24 07:10 PM - Post#2866589
I got a 1962 impala ss that needs the head light switch installed. Is there anyone that can post a pic of how the wires connect . I got what looks like 7 connectors colored red, white, black , orange, purple, green , yellow.Here is a pic of the headlight switch numbered to see if anyone can help me out . Thanks chevy fans .
https://ibb.co/6YqgD0x
https://ibb.co/LztzPMb
https://ibb.co/YXdvb5z
Edited by Da boss on 02-04-24 07:22 PM. Reason for edit: No reason given.
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
02-04-24 07:31 PM - Post#2866592
In response to Da boss
There is a factory plastic plug that all those wires plug into.
It’s part of every factory wiring harness and it plugs into the headlite switch with all the wires plugged into the correct slots in the plastic plug.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
https://paulstensland.com
Da boss
Reg: 02-03-24
02-04-24 07:43 PM - Post#2866593
In response to pvs409
thanks for the respond mine is missing that piece.
pvs409
Reg: 01-10-05
02-04-24 11:00 PM - Post#2866598
I might have a used one on a used good condition wiring harness.
American Autowire makes and sells the factory wiring harnesses and might sell you a plastic connector
here is a picture showing the connector on a new underdash wiring harness (gray connector in middle of picture)
https://www.google.com/search?q=picture+of+1 962+Ch...
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
02-05-24 02:35 AM - Post#2866599
This switch fits many years, pretty sure it’s the same in C2 vettes as well if that helps in looking for a used or new one.
Check the Classic listing.
https://www.classicindustries.com/product/1962/che...
63 Pontiac Parisienne Sport Coupe(CDN Chev mechanically (409, 4 speed),1998 Silverado Reg Cab 4WD, 62 Bel Air SC (sold), 59 El Camino (sold), 62 Bel Air SC(sold), 63 SWC Vette (sold),
Member #2194
Edited by DonSSDD on 02-05-24 02:39 AM. Reason for edit: No reason given.
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
02-05-24 09:08 AM - Post#2866604
I have a good used one if Paul doesn't.
Da boss
Reg: 02-03-24
02-05-24 02:53 PM - Post#2866613
In response to turbo38s10
I have 2 headlight switches and the cables are there. I don't need to buy them . I just need to connect the cables to the switch I just don't know which cables go on the switch. I'm looking to have someone post a picture of the installed cables to match up were they go. Sorry for the confusion.
DonSSDD
Reg: 08-21-01
02-05-24 03:24 PM - Post#2866616
What you need is the plastic connector that your wires plug into, then that connector plugs onto your switch. I was suggesting where you could find the plastic connector. If you have a plastic connector, the shop manual/shop manual/:supplement/assemb ly manual likely has the wiring schematic that will show you which wire plugs in which space on the plastic connector.
Member #2194
Da boss
Reg: 02-03-24
02-05-24 03:45 PM - Post#2866617
In response to DonSSDD
I got the plastic connector I got everything ready. I don't have a shop Manuel I was hoping someone could just connect the color wires to the right prongs on the headlight switch .
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
02-05-24 04:54 PM - Post#2866619
Does this help
Da boss
Reg: 02-03-24
02-05-24 06:45 PM - Post#2866625
Perfect . This is just what I needed. I'll have to wait for this rain to stop then hope I'll have my lights working right .
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
02-06-24 11:54 AM - Post#2866646
327
Loc: Ontario , Canada
Reg: 02-09-21
02-06-24 07:41 PM - Post#2866662
junky
Loc: Northeast CT
Reg: 06-27-10
02-08-24 05:24 AM - Post#2866696
Make sure to pull out the locking tabs on the wire connectors. They hold the connectors into the plastic housing. They had to be released to remove the plastic housing, and if the wires don't stay in when you push them into place, use your fingernail to pull the tabs out some more. You release them by putting a tiny flat-blade screwdriver in from the opposite side of the wire clip.
