Username Post: Won't turn over        (Topic#374441)
Gratefulchic
Loc: CT
Reg: 02-04-24
02-04-24 06:13 PM - Post#2866583
So I have a question for you. We bought an rv from one of my husband friends. It's a 92 winnebago. 454 chevy big block 56000 miles. We went to pick it up and it wouldn't stay started so they had their son in law who is a mechanic replace the plugs, oil change, coolant temperature sensor and distributor cap. It started so the called us to pick it up again....it wouldn't start again. So his soN in law said it needed a new computer. He fixed it, we picked it up. It started first shot, as I was going down the road the speedometer maxed out, oil pressure gauge maxed out and temperature gauge bottomed out. I got it home. Turned it off, the speedometer is showong 40mph and I tried starting it again to make sure because all the problems up til now and it won't start. It will try to turn over but just won't start. Sorry for the long story. Any ideas?????
02-05-24 07:33 AM - Post#2866602
    In response to Gratefulchic
Welcome to CT. Not knowing the skill level of whoever is working on this, here are some suggestions. Engine grounds to the frame must be confirmed. Wiring harness connections all need to be
checked. Do you have spark at the plugs, do the injectors spray fuel on cranking? Your issues will require a skilled tech to pin down the problem/s.
Execution time: 0.009 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:30 PM
