Username Post: Rims and tires for 1957        (Topic#374386)
AlfredB
Loc: BC, Canada
Reg: 01-22-24
01-23-24 12:25 PM - Post#2866221
I have factory stock wheels 14x5” with bias ply tires. The car wanders significantly. Front end has been completely rebuilt. I have been told that radial tires will solve the problem. I would like to go to a wider tire. Anyone know if wider rims available? Alternatively, what is the widest radial tire I can put on the factory stock rims?
01-23-24 02:11 PM - Post#2866223
    In response to AlfredB
I would suggest before you do anything with tires, look for any looseness in the gear box, steering linkage, suspension components and front end alignment.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
01-24-24 11:17 AM - Post#2866255
Agree. The car was designed for the 'stiffer' side walls of the bias ply tires. The radials will make the wander worse.
Is the suspension/steering configuration OEM/stock?
'Newer' different ratio steering boxes require approx 4 degrees of + caster to have proper 'return-to-center' performance, and to keep the car from 'wandering'. The OEM upper control arms can NOT come close (safely, max is only about + 1 1/2 degree).
Pete
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
03-16-24 02:40 PM - Post#2868016
it's been almost 2 months,
any follow up on rim choice?
any pics?
VC56S 2 door Sedan, 44 Years
Execution time: 1.799 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:04 PM
