Username Post: 71 sbc air in cooling sys        (Topic#374300)
J C
Loc: Orange Co. Calif
Reg: 04-17-04
01-07-24 10:20 PM - Post#2865701
Installed a new temp sensor and thermostat. Temp went up to 250 degrees. I assume I have a air lock probably at the thermostat. No flow through radiator. How do I remove the air. I was thinking of loosing the thermostat housing and getting coolant to flow out. Never had this problem before.
69RSZ28 71 Chevelle 79 Silverado 24K mi.
01-17-24 08:06 AM - Post#2866013
    In response to J C
did you drill a hole in the stat?
elcamino
elcamino
Reg: 03-30-00
02-24-24 01:16 PM - Post#2867199
    In response to J C
Have you tried parking the vehicle so the radiator cap is the highest part of the system and removing the cap and letting it idle? Heater on as well.
2021 GMC 4WD Sierra Denali Ultimate 6.2L/10-sp
2022 Polaris RZR XP 1000 Ride Command
2017 John Deere X738
Execution time: 0.366 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:47 PM
