Username Post: L31 vortec low vacuum        (Topic#374030)
zepplinc20
Reg: 04-02-07
11-16-23 09:14 AM - Post#2864211
Hoping someone might have some insight here. My L31 crate engine only has a couple thousand miles on it. I've carefully gone through the edelbrock carb. Adjusting the idle mixture I'm only getting 4 inHg (steady). Has an off idle stumble and smells rich but seems to have power when past the stumble. Brake boosters been replaced. I've sprayed carb cleaner everywhere with no change in idle. Next time I'm under the hood I'll verify initial timing but it should be 10-12.
11-16-23 09:55 AM - Post#2864212
    In response to zepplinc20
Without a giant cam or a big vacuum leak, never seen that low at idle. When did this start, timing checked with dist vac disconnected, gage known to be accurate?
Magnetocheck
Magnetocheck
Loc: Charlotte, NC, USA
Reg: 09-05-22
11-16-23 10:09 AM - Post#2864214
Agree with Shepherd. Never heard of vac that low with any kind of street cam at normal RPM. . Check the vac can for a leak. BTW, What is your idle RPM?
Bob
'65 Impala SS 396 Convertible
zepplinc20
Reg: 04-02-07
11-16-23 11:11 AM - Post#2864217
I've been thinking the same thing, I'm going to acquire another gauge just to verify. This project truck has been sitting a few years. It started after having issues with the carb getting clogged I believe. Eventually found the pickup strainer was the issue. Never seemed to run right after. I also recently replaced the plugs which looked fouled.
Edited by zepplinc20 on 11-16-23 11:15 AM. Reason for edit: No reason given.
zepplinc20
Reg: 04-02-07
11-16-23 11:11 AM - Post#2864218
    In response to Magnetocheck
800 rpm
zepplinc20
Reg: 04-02-07
11-17-23 05:02 PM - Post#2864250
Found the problem
https://imgur.com/g2T5lMb
https://imgur.com/a/7OUiCQj
https://imgur.com/a/RhWnoaW
https://imgur.com/a/5TDX8VC
Magnetocheck
Magnetocheck
Reg: 09-05-22
11-17-23 06:09 PM - Post#2864251
Way to go!
Bob
65_Impala
Reg: 12-29-02
11-18-23 09:12 PM - Post#2864266
Care to share what it was?
zepplinc20
Reg: 04-02-07
11-18-23 11:48 PM - Post#2864268
    In response to 65_Impala
It's in the videos I linked. Crane cams 99600 adjustable vacuum advance had a leak. Reinstalled a regular vacuum advance I had laying around.
zepplinc20
Reg: 04-02-07
11-21-23 11:18 AM - Post#2864328
Well turns out that wasn't THE vacuum leak. The vacuum advance was bad but it's still not fixing the problem. I had the carb dialed in nicely, but as soon as I started driving it around the problem returned. First the idle was rough and low, so I bumped it up. When I shut it off it dieseled. Then I made a trip to the parts store and it was idling at 1500 rpms. I noticed it was running decent when the choke was on. Last night when I parked it I readjusted the idle mixture screws and got a huge rpm increase when I turned the driver side out. I then tried to lower the idle back down but the idle screw isn't even touching the linkage and it's idling at 1000 rpms. So clearly more work is to be done.
Magnetocheck
Magnetocheck
Reg: 09-05-22
11-21-23 12:07 PM - Post#2864330
Take a look at the fast idle cam/choke set up on the other side of the carb Maybe it is messed up holding the throttle plates open. Bad spring, bent linkage, something?
Bob
11-21-23 01:20 PM - Post#2864334
Make sure the secondaries in the carb are not partially open.
zepplinc20
Reg: 04-02-07
11-21-23 05:29 PM - Post#2864339
So today I addressed the pcv which hadn't been eliminated. It had the original type with 2 outlets, one to carb and the other to the vapor canister. I replaced it with a new one outlet to carb and new hose. I dialed my idle mixture back in with tach and vacuum gauge. It seems to be back to running pretty well. What little driving I was able to do things seem promising. Even the off-idle stumble that it had is 70% gone. Fingers crossed the problem is solved and I can move on to carb calibration and dist recurve. I guess it was throwing me for a loop that it wasn't an external leak detectable with carb cleaner.
Execution time: 0.151 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:14 AM
