50_Fastback
Loc: California Central Coast
Reg: 09-08-14
11-15-23 10:22 AM - Post#2864192
Does anyone know if the door molding (spear) on a 50 fleetline is the same for a 2dr versus a 4dr?
Ron Starkey
Life's full of risks..........take one!
'50 Fleetline 350/200r4
eplantage
Loc: Southern MN
Reg: 03-15-04
11-15-23 11:04 AM - Post#2864195
In response to 50_Fastback
I believe the 2 door spears are longer than the 4 door spears on all models, as are the doors themselves.
Age: 69 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe |
Edited by eplantage on 11-15-23 11:05 AM. Reason for edit: No reason given.
buddhabelly
Loc: Calgary, AB
Reg: 12-05-14
11-16-23 07:50 PM - Post#2864227
In response to eplantage
I would suggest contacting suppliers to verify lengths. I did some quick research and the spears are listed under the same number, GM4560098. It appears that the spears are the same over the two years, while the doors are different lengths, 2dr. or 4 dr.
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
11-16-23 09:41 PM - Post#2864228
buddhabelly has it correct. There was only one lower outer panel moulding used during 1949-50 on Deluxe models. It didn't matter if the car was a Styleline, Fleetline, 2-Door or 4-Door, left or right....only one is listed. I used a 2 and 4-Door Fleetline as an example. You can see how that one moulding appeared on either length door.
The part number I get from my 1959 Master Parts Catalog however is 3759447. It is listed as 38-1/2" long and 7/8" wide and in 1959 cost $4.80 each.
1951 Fleetline Preservation
'50 Styleline DeLuxe 4 DOOR SEDAN (Mist Green) |
eplantage
Loc: Southern MN
Reg: 03-15-04
11-17-23 04:43 AM - Post#2864230
In response to RAM_51
Wow, good to know. Thanks.
50_Fastback
Reg: 09-08-14
11-17-23 08:25 AM - Post#2864237
As always, you guys have the answers!
Thank You!!
Ron Starkey
