Username Post: Very stupid question        (Topic#374028)
gcrkfrd
"6th Year" Platinum Supporting Member
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
11-15-23 07:29 AM - Post#2864182
I have a 4 bolt 350, and a crank that came with it. Took it to be bored because of cylinder scratches. Got it back 30 over. Shop said the crank was not a truck crank, turned it 10 under. Ordered stock replacement cast pistons, One place, and stock replacement rods another. Managed to put pistons on rods, installed new mains and rod bearings. Put Number One, in block, and counter weights, on crank hit bottom of piston skirt while rotating, and piston comes up out of cylinder, about 1/8". What are your thoughts?
1952 Styleline Sedan-
Baby Blue 1967 C-20, Survivor.
T-Bucket, Small Blocks, and parts everywhere
11-15-23 07:57 AM - Post#2864186
    In response to gcrkfrd
Sounds like wrong crank? What is the casting number? You could also measure the total stroke if you can get one revolution, but it sounds like that won't work.
Edited by Shepherd on 11-15-23 07:59 AM. Reason for edit: No reason given.
Magnetocheck
Magnetocheck
Loc: Charlotte, NC, USA
Reg: 09-05-22
11-15-23 08:35 AM - Post#2864190
No such thing as a stupid question, only stupid answers! Keep us posted on your progress
Bob
'65 Impala SS 396 Convertible
Member #409
11-15-23 10:36 AM - Post#2864193
It's not the wrong crank, it's the wrong pistons.
11-15-23 12:07 PM - Post#2864197
    In response to Rick_L
Could be, but the assumption is the machine shop would know better. :sad :
Member #409
11-15-23 06:22 PM - Post#2864203
If the pistons stick out past the deck, either the pistons are for a smaller stroke than expected, or the crank has more stroke than expected.
Since the engine is said to be a 350, if 327 pistons were used they would stick out. But there is no factory crank that has more stroke that would actually fit in the block.
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
11-15-23 07:34 PM - Post#2864204
I ordered another set of pistons, will try again next week. Thank you for your responses.
11-16-23 06:03 AM - Post#2864206
Agreed, but what crank is in there, no info to be sure. But, most likely it is the piston/ rod combo.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
11-16-23 08:20 AM - Post#2864209
Truely a question.
How about the 400 cu in sbc factory engine crank? 'Fit' the 350 block?
Pete
Member #409
11-16-23 10:16 AM - Post#2864215
    In response to japete92
The main bearing journals on a 400 SBC crank are bigger than on a 350 crank.
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
11-16-23 11:44 AM - Post#2864220
Machine shop only had block and crank, it appears that somewhere, in my ordering parts, I obtained 327 pistons 30 over. Crank casting #3932442
Fairly typical problem with our hobby-Order parts, they set there for weeks or months, maybe years then you find out too late, and have to order more parts, end up with a large inventory of possibly unknown pieces.
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
11-17-23 10:08 AM - Post#2864240
That is a 350 crank...and it looks like it is not a HD crank.
https://www.mortec.com/cranks.htm#google_vignette
11-18-23 09:31 AM - Post#2864257
uh, a good machine shop would want the pistons in hand to measure before bore and hone.
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
11-28-23 09:38 AM - Post#2864569
My question today-Is there anything wrong with using bushed rods and snap ring pistons and pins in the assembly of my street driven 350?
11-28-23 02:15 PM - Post#2864579
Not if it is done right.
Execution time: 0.238 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:11 AM
