DHMelton
Loc: Central Arizona
Reg: 04-10-22
11-13-23 07:39 AM - Post#2864126
Specifically the areas where the speedo housing screws to the main instrument cluster bezel.
Also, can anyone confirm the screw size that holds the speed housing to the main cluster, where the speedo lens is sandwiched?
Are those #8 or #10 screws that are used?
I would like to pre-assemble, with new hardware the replacement instrument bezel, speedo lens and speedo housing before i remove the existing one from the car next week, to replace it.
I don't know whats in the car now, if all the screws are there, proper size, etc, and want to do quick swap, not find out I need to buy more screws, etc after I get it out.
Thanks,
Doug
Edited by DHMelton on 11-13-23 07:40 AM. Reason for edit: No reason given.
